Author Topic: Front End Renewal  (Read 1494 times)
Offline 'cudaCruiser
    • My '72 B5 'cuda
Front End Renewal
« on: February 24, 2014 - 02:45:55 PM »
I'll be getting my front end K brace assembly ready to re-install once the 'cuda is out of the paint shop.
I'll be disassembling it to clean and replace the needed parts.
What should I be on the look out for?
Rebuild the steering gear box?
Replace steering linkage?
Mickey
"The man who complains about the way the ball bounces is likely to be the one who dropped it." Lou Holtz
Offline anlauto
Re: Front End Renewal
« Reply #1 on: February 24, 2014 - 03:27:09 PM »
Do it all, do it once....
-Inner/Outer tie rods
-Idler arm
-Pitman arm
-LCA bushings
-Lower ball joints
-UCA bushings
-Upper ball joints
-Strut bar bushings
-Sway bar links/bushings
-Rebuilt box
« Reply #2 on: February 24, 2014 - 08:39:55 PM »
I add gussets to the steering box mount & left engine mount area , you can also weld up a lot of the seams & improve the strength of the K frame ,  a front rad support brace will help too , I use Poly bushings , you can get offset Moog rubber upper bushings to improve the caster adjustment  , you can use larger C body tie rods for the same cost ,  optionally you can also use billet adjustable strut rods . Firm Feel steering box or adjust the factory box with shims .
Offline RCCDrew
« Reply #3 on: February 25, 2014 - 07:31:26 AM »
Anyone have apart number for those moog bushings?
Offline jhaag
« Reply #4 on: February 25, 2014 - 12:34:17 PM »
Moog pn#k7103 are offset bushings. all front end part numbers in the sticky note top of page.
love 70 Challengers
Offline chuck
« Reply #5 on: March 07, 2014 - 06:28:38 PM »
Is the flaming river steering box a good choice or go with stock and will it affect header clearance and where is the best place to get them
« Reply #6 on: March 07, 2014 - 10:11:11 PM »
I have not used Flaming River , but Firm Feel or Steer & gear have tweaked boxes that give great feel , or there is a way to shim your box to get better feel
