Author Topic: lca ?'s  (Read 571 times)
Offline Madmaxx
lca ?'s
« on: February 26, 2014 - 10:34:52 PM »
72 cuda..has to much neg camber..pass. side is very noticeable...I have it at my friends shop...the cams are maxed out, so nothing to gain there..he's wondering if someone has installed a-body lca''s (which he thinks are longer than e-body lca)..is there a way we can tell what lca's are on the car now?...I have been told b and e body lca's are the same?..thanks!
Re: lca ?'s
« Reply #1 on: February 27, 2014 - 12:18:19 AM »
Found on the net...I had heard the a-body lca was longer
B/E Body Lowers Are 12.8" Center To Center
A Body Lowers Are 13.3" Center To Center
http://www.moparchat.com/forums/showthread.php?t=120948
Re: lca ?'s
« Reply #2 on: February 27, 2014 - 04:58:43 AM »
I found the A-Body LCA to be 3/16 longer than E/B-Body's.
A-body on the left, e-body on the right , notice the shock mounting is slightly different. The shock hole is closer to the rivet on e-body . Also the A-Body sticks out where the lower ball joint stops contact the LCA , on the e-body the it is the opposite they are shaped in.  Check to be sure the LCA bushing are not worn too?
Offline Madmaxx
Re: lca ?'s
« Reply #3 on: February 27, 2014 - 08:05:15 AM »
perfect that's what I was looking for!..many thanks!!  pics are awesome thank you guys..that will make my time laying on the cold floor much shorter..thanks!
Re: lca ?'s
« Reply #4 on: February 27, 2014 - 08:17:33 AM »
Np problem, glad to help! If you had A-Body LCA also the strut rod would be somewhat bound up if you had the stock bushings
