Author Topic: would this be a good brake rotor?  (Read 2396 times)
Offline halle09
« on: March 02, 2014 - 06:42:43 PM »
i would like to get new rotors and saw these and wanna know what you guys think? and i would like to get the firm feel pads to go along with them. Any experience with either pad or rotor?
http://www.cquence.net/plymouth-barracuda-1973-street-series-cross-drilled-slotted-brake-rotors.html?gclid=CIqdt4v_9LwCFW9p7AodkRMAzQ
Re: would this be a good brake rotor?
« Reply #1 on: March 02, 2014 - 07:35:39 PM »
I get mine here?..... free shipping.
http://www.r1concepts.com/default.aspx
Offline anlauto
« Reply #2 on: March 02, 2014 - 08:04:48 PM »
I don't understand, what hub do these go on ? In 1973 a Barracuda has a one piece hub/rotor  :dunno:
« Reply #3 on: March 02, 2014 - 08:11:40 PM »
I think it's just a generic picture?
Offline anlauto
« Reply #4 on: March 02, 2014 - 08:14:36 PM »
Okay, if that's the case...Do they make a "stock" size drilled and slotted rotor the has a hub as well that would fit a standard 70-74 E Body ? If they do, that would be cool :smokin:
« Reply #5 on: March 02, 2014 - 08:28:33 PM »
I got drilled and slotted for the "big rotor set up  ('76-'79 B-body or 79-up R-body St. Regis, etc.)  from them. I also got my current 73 C-Body drilled and slotted from them too.
Offline anlauto
« Reply #6 on: March 02, 2014 - 08:43:55 PM »
Cool...I did not know something like that was available...learn me sumtin everyday :icon16:
Offline 73EStroker
« Reply #7 on: March 02, 2014 - 08:56:25 PM »
Those will work but I bought mine from R1 same as Brad did. Their products are made in US. They are more expensive but the quality is there. Careful of cheap drilled rotors. They may crack prematurely. I went only for the slotted rotors anyway even from R1 because of the same reason.
Barry (Salmon Arm)
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: March 03, 2014 - 02:07:47 PM »
They look really good but you need a wide caliper to put these babies on.
« Reply #9 on: March 03, 2014 - 02:35:40 PM »
The picture in the link is just a generic picture of a rotor , nothing specific.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: March 03, 2014 - 04:07:46 PM »
Got a pic of the width of these babies then? Might use them somewhat soon.
B
Offline halle09
« Reply #11 on: March 03, 2014 - 04:16:49 PM »
when you buy new rotors dont you have to buy the wheel bearings and bearing cones and put them in the new rotor? and reading the service manual i see that there is a seal on the back side. is there a kit that has everything together to do this at once while im in there?
Offline tman
« Reply #12 on: March 03, 2014 - 04:34:00 PM »
IF they are oem spec rotor, you should be able to buy new bearings and seal from your local parts store or online store.
Offline halle09
« Reply #13 on: March 03, 2014 - 05:08:36 PM »
any recommended bearing brands for these? timken?
« Reply #14 on: March 03, 2014 - 07:21:58 PM »
Timken is good , if you can find them .
SKF Toyo brg
