Author Topic: would this be a good brake rotor?  (Read 2398 times)
Re: would this be a good brake rotor?
« Reply #15 on: March 03, 2014 - 08:53:35 PM »
Got a pic of the width of these babies then? Might use them somewhat soon.
B
Of what rotor? 73 C=Body that I'm using now is 1.250 thick. But keep in mind I'm also using the 73 C-Body spindle. Cass has a kit that uses C-Body rotors but 71-72 I think? on a e-body spindle I think too?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #16 on: March 03, 2014 - 10:07:57 PM »
Thanks I'll take some measurements!
 :2thumbs:
Offline 73EStroker
« Reply #17 on: March 03, 2014 - 11:02:10 PM »
Just add to what Brad said. Cass sells a c body kit for e body spindles and a separate kit that adapts 73-75 a body drum spindles on 73 c body rotors that fit Challengers. That kit has a small sleeve to adapt the larger diameter race of the c body outer bearing to the a body spindle. No issues with the large inner bearing.
Barry (Salmon Arm)
Offline tman
« Reply #18 on: March 04, 2014 - 12:05:13 AM »
I think Rockauto.com has Timken.
« Reply #19 on: March 04, 2014 - 03:53:07 PM »
Okay, if that's the case...Do they make a "stock" size drilled and slotted rotor the has a hub as well that would fit a standard 70-74 E Body ? If they do, that would be cool :smokin:
I have stock size drilled and slotted Baer rotors. Got them from AutoAnything in Cali. $175 a pair when I bought them but have since gone up to about $300.  Free shipping.
Offline halle09
« Reply #20 on: March 04, 2014 - 04:42:27 PM »
what is your experience with them? and what pads are you using? i will be having drilled and slotted in the front and drums in the back.
« Reply #21 on: March 04, 2014 - 05:04:05 PM »
I use bendix ceramic pads from Summit. LAA66 pointed me at them. Quite happy with their performance.
http://www.summitracing.com/dom/search/brand/bendix-brakes/part-type/brake-pads/make/dodge/model/challenger/year/1973
Offline halle09
« Reply #22 on: March 04, 2014 - 06:21:07 PM »
did you see a big difference using drilled and slotted rotors and those pads from stock? just trying to see if its worth the upgrade
« Reply #23 on: March 04, 2014 - 07:06:35 PM »
Happy with braking power. 440 in the nose and it stops well. Biggest difference imo is less fade.
