Author Topic: One wire alternator  (Read 1023 times)
Offline 530grafix
One wire alternator
« on: March 02, 2014 - 10:14:23 PM »
Hello, I have a one wire alternator with the regulator on the back. Do I need to use the black voltage regulator from the firewall? I also just purchased the mopar performance electronic ignition with orange box. And a new engine wiring harness from classic industries that is modified for an electronic ignition.
Thanks for any help.
Thanks
Sent from my LG-D801 using Tapatalk
Re: One wire alternator
« Reply #1 on: March 02, 2014 - 10:40:04 PM »
No you only need one reg & there is one on the alt
Offline 530grafix
« Reply #2 on: March 03, 2014 - 12:17:08 AM »
Thanks.
« Reply #3 on: February 23, 2015 - 02:52:21 PM »
CP,
to use the new one wire alternator, do you need to jump the green and blue wires in the factory regulator plug to bypass it?
« Reply #4 on: February 23, 2015 - 06:08:03 PM »
No . the blue wire feeds 12v power to the reb & the green wire just controls grounding of the field , with a 1 wire alt it will have an internal regulator , so leaving the reg unplugged is all you need to do * protect the blue wire at the alt so it will not short .
