Author Topic: 8- 3/4 Noise,Help  (Read 1746 times)
Offline acudadude
8- 3/4 Noise,Help
« on: March 09, 2014 - 10:43:57 AM »
Hi I have a 8 3/4 in my cuda that has 3.23 gears after the car sits for some time when i try to roll the car around i get a slight clunking noise from the rearend. The bearings seem good , u joints all new, when i jack up the car to ck for the noise its not here? After i drive the car a little the noise is gone. Could this be the clutch ? Any help would be great Thanks You!
Offline ChallengerHK
Re: 8- 3/4 Noise,Help
« Reply #1 on: March 09, 2014 - 10:54:26 AM »
Do you have Suregrip?
- Han Solo, Star Wars
Offline acudadude
« Reply #2 on: March 09, 2014 - 11:05:53 AM »
Yes its a suregrip thanks
Offline DocMel
« Reply #3 on: March 09, 2014 - 11:40:00 AM »
Start with the very easiest fix/diagnoses first
First, remember that our rear ends are over 40 years old.  And all that time, most previous owners dont perform even the basic maintenance on them., let alone fix a prob that might lie in the rear end itself.  It can get a little expensive if you need a rebuild
I recommend the following, in order \
1.  Change out ALL the u joints:  Front and rear;  Its a a cheap job, and anyone can do it:  Chances are your joints have never been changed.  This might take the clunk out.  Wore out u joints typically sound like that.
2. Check out all transmission mounts and engine mounts.  Ensure they are not worn or loose, allowing tourque to flex the drive train to a point were you get a clunk
3.  If you do the above, and I really recommend that you do, to rule out a wore out dif.   If you do  still suspect a rear end prob, you need to have it checked out by a pro
Offline acudadude
« Reply #4 on: March 09, 2014 - 12:05:50 PM »
Hi Doc, Both u joints are new, all motor and trans mounts are new.  Still have the noise when the car sits for sometime. Thanks
Offline ToxicWolf
« Reply #5 on: March 09, 2014 - 12:35:08 PM »
Are you sure that's what is making the noise?  I had a clunking noise like that. Turned out that I had tires on the car that would develop flat spots on them when it sat for awhile. Once it rolled some, the flat spots worked out and there was no clunking. Just a thought.
Offline BIGSHCLUNK
« Reply #6 on: March 09, 2014 - 12:57:48 PM »
Maybe to much lash? (wear)  :dunno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline mopar jack
« Reply #7 on: March 09, 2014 - 01:18:38 PM »
If the noise is more noticabe on tight turns I would recommend  adding a tube of Sta-lube Equa-torque to the rear end fluid to see if that stops the noise. After adding the fluid take the car out to a parking lot and do a couple of figure 8's to see if the noise is gone.
« Reply #8 on: March 09, 2014 - 01:31:05 PM »
 :iagree: That's what I was thinking too.
Offline acudadude
« Reply #9 on: March 09, 2014 - 03:17:25 PM »
Tires are pretty new no flat spots? Sta- lube is that the stuff they call skunk oil that stinks ? I guess iam gonna have to do some more testing Thanks.
« Reply #10 on: March 09, 2014 - 06:03:26 PM »
Check the end play first , should be around .010 , there is a spacer between the axles that can make noise if the axles are loose as well , check U joints start with simple stuff
