Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
Clutch Free Play: Adjusted out, Pedal Still Low
« previous
next »
Print
Pages:
1
2
Author
Topic: Clutch Free Play: Adjusted out, Pedal Still Low (Read 2888 times)
Chryco Psycho
Administrator
C-C.com Guru
Re: Clutch Free Play: Adjusted out, Pedal Still Low
Reply #15 on:
March 16, 2014 - 07:56:10 AM »
I used to get spares all the time from the wreckers & always had a few longer ones , the dodge trucks have longer ones as well of course all my spares are where now
Logged
73EStroker
Sr. Member
Reply #16 on:
March 17, 2014 - 02:15:26 PM »
You also require a large diameter flat washer between the adjusting nut and the rubber on the bellcrank side. And you only require the locking nut on the bellcrank side. Turf the other one and is that adjuster nut on backwards. Flat side should sit against the missing washer. That will take a bit of spongy feel out of the clutch pedal movement.
Logged
Barry (Salmon Arm)
Chryco Psycho
Administrator
C-C.com Guru
Reply #17 on:
March 17, 2014 - 06:53:18 PM »
He is running the steel ball pivot used on the trucks
Logged
Topcat
C-C.com Expert
Member since 9/16/04
Reply #18 on:
April 05, 2014 - 10:17:19 PM »
Quote from: Chryco Psycho on March 15, 2014 - 10:45:03 PM
looks like you need a longer adjuster rod from a different application
Put in the longer A body rod today.
It worked.
Still a mystery why I needed just a few more threads out to get the pedal freeplay right.
Logged
Sleepychallenger
Sr. Member
Reply #19 on:
April 06, 2014 - 12:10:20 AM »
Will it cause problems if the longer rod isnt used?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #20 on:
April 06, 2014 - 07:38:32 AM »
the finger height on the clutch pressure plate may not be the same as factory , yes it will cause problems using the shorter rod , the clutch may never full release causing it to drag making it much harder to shift etc
Logged
Print
Pages:
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
