18 spline 3rd gear question
Author Topic: 18 spline 3rd gear question  (Read 680 times)
Offline vic340
« on: March 12, 2014 - 05:49:05 PM »
Hi group,
Is a T314-11B 26 tooth 3rd gear right for my 1969 - 2.65 ratio trans which calls for an aftermarket WT294-11C.  I picked one up (T314-11B) and it looks identical to my OEM gear.  Both are 26 tooth, same outside diameter, gear pitch looks identical  and neither has the identifying grooves which is correct for my trans.   It sure looks right but I’m confused between the B and C designation although I know they are from different manufacturers.   Any thoughts?
Thanks,
Vic
Offline PlumCraZRT
Re: 18 spline 3rd gear question
« Reply #1 on: March 12, 2014 - 07:22:14 PM »
...I’m confused between the B and C designation although I know they are from different manufacturers.   Any thoughts?
The B and C designations may just be a revision number of the part.  You could also try calling the manufacturers to verify.
mmmmm.... Mopar.... *drool*
