Author Topic: Speedometer gear  (Read 1041 times)
Offline A110235
  • '71 Challenger JH23G1B
Speedometer gear
« on: March 12, 2014 - 10:42:45 PM »
I went for a drive this weekend and my new speedometer didn't work.  I disconnected the cable from the 4-speed and I can spin it with a drill and it reads right at the gauge.  What would be the problem in the transmission?  I took the retainer off and started to pull the housing where the cable connects at the trans when I discovered it was a really fast way to empty the all the fluid.  :banghead:  What will be the fix for this?
Kyle
Nashville, TN         Member since October 09, 2004
Offline 67vertman
  • Member since 9-23-2005
Re: Speedometer gear
« Reply #1 on: March 12, 2014 - 10:48:47 PM »
It is just a plastic gear inside, it could have broken or is stripped, and yes removing the speedo gear will drain most the fluid from the trans, I found out the same way you did.  :bricks1:
Put a drain pan under it to catch the fluid, if you want to reuse it.
Offline A110235
« Reply #2 on: March 13, 2014 - 12:03:56 AM »
Ok, thanks for the info.  I assume they are still available, where can I get the gears from?  And how do I know which one I need?  Isn't there some formula for which one I would need based on tire height and rear gear ratio?  I'd say it is a pretty slim chance that I have the correct one where my speedometer would read right.
Kyle
« Reply #3 on: March 13, 2014 - 12:48:44 AM »
The speedo drive has to be clocked so the gear will mesh properly with the output shaft .
Offline A110235
« Reply #4 on: March 13, 2014 - 09:54:27 AM »
I'm not looking at it now, but I remember the two prongs of the retainer seated in two little notches in the body of the housing.  Maybe it is 180* out?  Is there anything that helps to show what the proper alignment is?
Kyle
« Reply #5 on: March 13, 2014 - 07:18:09 PM »
Yes , the housing has 3 group markings for different tooth counts so it has to be clocked according to the tooth count
Offline 67vertman
« Reply #6 on: March 13, 2014 - 10:53:09 PM »
This helps a lot in slecting the right gear to pinion ratio
http://www.moparts.org/Tech/tech/pages/speedo.html
Offline A110235
« Reply #7 on: March 13, 2014 - 11:10:17 PM »
Sweet!  Thanks for the info guys.
Kyle
