Author Topic: Ignition switch  (Read 1378 times)
Offline usraptr
Ignition switch
« on: March 13, 2014 - 03:10:23 PM »
I'm in the process of disassembling my steering column for restoration.  I've been following the article on http://www.moparmusclemagazine.com/techarticles/suspension/mopp_0308_rebuilding_steering_column/ and the excellent write up on http://ron.peterro.com/?p=20
I;ve got the column completely disassembled except for the ignition switch.  I've removed everything else from the housing as instructed.  I've tried pushing down on the release pin through the small hole as instructed and nothing happens.  Even taped the the probe lightly with a hammer in case it was stuck.  Still wont' release.  I did notice that with the key removed from the switch,  the outside of the housing where the key goes in will turn 360 degrees.  If I put the key in it operates correctly and stops where it is supposed to.  Is it normal for it to turn 360 degrees with no key and the other components removed?  I've looked down the small hole with a flashlight and there doesn't appear to be a pin in there.  Any ideas on how to get the switch out?  Drill out where the pin is supposed to be?  Any advice is greatly appreciated.
Thanks
(Edited 8-1-17)
Re: Ignition switch
« Reply #1 on: March 13, 2014 - 07:40:23 PM »
I believe the switch has to be turned on to depress the retainer
Offline usraptr
Re: Ignition switch
« Reply #2 on: March 14, 2014 - 12:18:14 AM »
Got it out. Just took some more finagling.  :bigsmile:
(Edited 8-1-17)
Re: Ignition switch
« Reply #3 on: March 23, 2014 - 11:51:12 AM »
It's not supposed to spin 360* though. I think you will find a small tack weld that has let go. I had one do the same thing.
Re: Ignition switch
« Reply #4 on: March 23, 2014 - 08:52:55 PM »
The chrome bezel should not spin , it is actually a cast tab on the cylinder to keep the chrome from rotating but it breaks
Re: Ignition switch
« Reply #5 on: March 23, 2014 - 09:17:55 PM »
Thanks
Put the key in while putting the pin into the hole and the cylinder will release.
I went thru the same issue.
The steel bezel is crimped over the key mechanism. It wears out and then the key outer housing spins.
Offline usraptr
Re: Ignition switch
« Reply #6 on: March 24, 2014 - 08:32:30 PM »
[/quote]
Yep, figured that out when I got it out.  thanks for all the help guys!   :2thumbs:
(Edited 8-1-17)
