Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Steering coupler
« previous
next »
Print
Pages: [
1
Author
Topic: Steering coupler (Read 760 times)
usraptr
Sr. Member
Steering coupler
on:
March 13, 2014 - 03:13:57 PM »
I'm in the process of disassembling my steering column for restoration. I've been following the article on
http://www.moparmusclemagazine.com/techarticles/suspension/mopp_0308_rebuilding_steering_column/
and the excellent write up on
http://ron.peterro.com/?p=20
I've got the column completely disassembled except for the steering coupler. It appears that when you remove the drift pin that it should slide out of the housing per the above instructions. But mine does not. It's stuck. I did notice a spring type clip holding the shoes in place. Do I need to removed the spring clip first and if so how do I do that? So far I haven't tried to force it off as I wanted to make sure I'm not missing something first. Advice would be greatly appreciated.
thanks
Logged
1970 Plymouth 'Cuda. Matching numbers 440 U Code, 4 speed pistol grip, Rallye dash, AM 8 Track, Shaker hood, 15 inch rallye wheels, Dana 60 4.10, Super Track Pak. One of 134 - 440 "U" coupes codes built in 1970 and one of 100 - 440 Super Track Paks built in 1970.
Restoration pictures at:
http://spanks4thememory.smugmug.com/Cars/70-Cuda/7240639_M24oi#465274575_2MBqW
(Edited 8-1-17)
"usraptr" = United States raptor - bird of prey = United States Bald Eagle. FYI, somebody else thought of it first so I had to drop the "O" in raptor.
burdar
Sr. Resident
Re: Steering coupler
Reply #1 on:
March 13, 2014 - 04:59:50 PM »
The only thing holding the shoes and spring clip inside the coupler is a little pin. It's at the end of the coupler.(towards the firewall) You can get a little rough with it if you have to. The large pin in the bottom of the steering shaft is hardened and you won't hurt it. I forced the coupler apart on my Dart. The shoes broke in half. I had to reuse the original spring clip because the replacement was too tall for some reason. Don't throw any parts out until it's all back together.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
March 13, 2014 - 07:39:11 PM »
I used a rolling head pry bar to go inside the coupler & pry the pin as far up as possible , yours may be hangin up due to not being all the way out ,
Logged
usraptr
Sr. Member
Reply #3 on:
March 14, 2014 - 12:20:26 AM »
Thanks, I got it out. Just took a little more elbow grease than I was originally using. All the grease had dried up and was causing it to hang up.
Logged
(Edited 8-1-17)
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Steering coupler
