Author Topic: Fuel sending unit wire connector  (Read 885 times)
Offline ff6849
« on: March 14, 2014 - 09:39:21 AM »
I need to get the fuel sending unit gauge connector. Its rubber/plastic connector that slides on the threaded post on the sending unit.  I have Google it a several different ways unable to locate it.
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Re: Fuel sending unit wire connector
« Reply #1 on: March 14, 2014 - 03:04:48 PM »
That connector is part of the rear wiring harness. I wonder if some aftermarket company that makes replacement wiring harness's can help you?
Offline ntstlgl1970
  • T a c o c a t
« Reply #2 on: March 14, 2014 - 03:09:56 PM »
wrecking yard - also I think it is the same type on the brake warning light switch on the brake distribution/proportioning/combination valve if you are not concerned about originality (for many years and models)
Offline Plum6Pak
  • Plum6Pak
« Reply #3 on: March 14, 2014 - 03:20:34 PM »
Here's a link to a warehouse that has just about every pigtail known to man. I downloaded the catalog, they've probably got what you need if you can find it!
http://auveco.com/
Offline DocMel
« Reply #4 on: March 17, 2014 - 01:38:35 PM »
I have one:  PM  me if interested
