Hi all,
I need help, bought a set of OER gauges, new after market instrument voltage regulator, bench tested regulator, all works fine until I plug the small wire harness to the instruments, then I get no voltage out of regulator, just a buzzing noise. If IVR is disconnected from gauges test lite shows flashing at the out terminal like it should, plug in one gauge then there is no output only a buzzing noise. Anybody got any idea about what I could be doing wrong?
Thanks to all,
Fred
fredmopar@aol.com
