Author Topic: Roof drip rail mouldings sealant  (Read 1106 times)
Offline acudadude
« on: March 15, 2014 - 11:06:09 AM »
Can anyone tell me what to use or what the factory used on the space between the roof and drip rail mouldings ?
Offline Surfmichaels
Re: Roof drip rail mouldings sealant
« Reply #1 on: March 15, 2014 - 11:10:54 AM »
If I understand the pic, mine was filled with seam sealer but near the end where your pic is it actually looks like it was filled with lead to blend it back to the body.
Offline acudadude
« Reply #2 on: March 16, 2014 - 10:02:24 AM »
Thanks Surf, If i use seam sealer any type or brand do you recommend? Yes i did see the lead where the roof and quarter are attached .
Offline shawge
  • Zoiks!!
« Reply #3 on: March 16, 2014 - 05:21:41 PM »
I used Fusor 129.  8 minute work time, looks close to OEM, and it can be sanded/painted in 30 minutes.  The only problem is that it needs a special applicator gun.
- Jerry
« Reply #4 on: March 21, 2014 - 07:57:27 PM »
I'm not using sealer again, I was currently planning on just flooding the seems with the epoxy primer, but I'm not fully committed yet...
« Last Edit: March 21, 2014 - 09:11:43 PM by Surfmichaels »
Offline jimynick
« Reply #5 on: March 22, 2014 - 12:06:22 AM »
Don't do that. It won't take the flexing and will not only crack the paint, it'll leak again, too. Use a good seam sealer or bonding agent and save yourself the misery.  :thumbsup:
« Reply #6 on: March 22, 2014 - 12:45:47 AM »
Any suggestion on bonding agent? Where ever there was seam sealer there was rust, and because the Interior will be bare (race car style) I was looking for a cleaner solution. I saw cavity waxes and items in that vain but haven't been able to find a lot of use cases in the forum...
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #7 on: March 22, 2014 - 06:52:02 PM »
That iss mostly because the old seam sealer got brittle and cracked letting water in behind it. Use a good quality urethane seam sealer and it will last a lot longer than the old stuff. The other trick id to prime the area first ,then seam sealer, then prime again.
https://www.google.com/#q=3m+urethane+seam+sealer&tbm=shop&spd=2430133381822734209
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
« Reply #8 on: March 22, 2014 - 09:28:13 PM »
Thanks, I'll look into that. I don't expect this car to see much weather but I want to put it back together right.....
« Last Edit: March 22, 2014 - 10:04:25 PM by Surfmichaels »
