Author Topic: JAN 1970 CAST,,, 440 SHORT BLOCK  (Read 764 times)
Offline 71cudafish
« on: March 17, 2014 - 12:16:15 PM »
NEED TO MOVE SOME IRON,,STD 440 JANUARY 1970 CAST DATE SHORT BLOCK,INCLUDES 2 SETS OF  HEADS,,2 FOR SURE ARE UNLEAD HEADS,,,,OTHER 2 ARE DIFF  # ,, PROB FROM  BIG MOPAR ,,NOT HP,,, HAVE PULLEYS, WATER PUMP w/ CAST IRON  HOUSING,, OIL PAN AND TIMING COVER ON,,,,,600 CASH TAKES IT ALL,PICK UP ONLY,,,,STD BORE,  BORES ARE CLEAN ,Mark,,, do not know  how to send pics sorry,,,PM   if  interest  ,,,in  ohio   THANKS :wavingflag:
Offline 71cudafish
Re: JAN 1970 CAST,,, 440 SHORT BLOCK
« Reply #1 on: March 21, 2014 - 11:20:50 PM »
bump,engine turns smooth and easy :wavingflag: w/cam inplace,,,all 4 heads w/valves,springs,hdw....
« Last Edit: March 21, 2014 - 11:35:35 PM by 71cudafish »
Offline 72cudamaan
« Reply #2 on: March 22, 2014 - 10:12:09 AM »
You're much better off with pictures. Use the attachment button below the reply box,click browse and
attach a picture from your files. Resize if necessary first. Casting #s are also a plus.
If I cant fix it, it's broke
Andy  (phukker whither)
