Will a 440 and 727 fit into a 1967 Barracuda
Author Topic: Will a 440 and 727 fit into a 1967 Barracuda  (Read 4776 times)
Offline my70challenger
« on: April 14, 2005 - 11:51:31 AM »
I found a deal on a 1967 Barracuda locally. It looks like a small block 318 with auto trans and column shift. I have a 440 with a 727 trans. Would they swap into the 67 body with out allot of trouble?????
Thanks,
Jonesy.
Re: Will a 440 and 727 fit into a 1967 Barracuda
« Reply #1 on: April 14, 2005 - 12:05:08 PM »
67 was the first year for the bigger engine compartment in tyhe A bodys & yes i fits .... without a lot of trouble is a matter of opinion , there are special exahst manifolds or chassis & fenderwell headers available to fit as well
Offline 1973challenger360
« Reply #2 on: April 14, 2005 - 12:07:35 PM »
If its a factory motor its a 273,   the 440 will fit   read very tight a hemi will fit in there.     The motor is very heavy for that small car and will be a pain to work on      but it will scream in a strait line, keep it out of corners.
They put 383 in 67-69
440 in 69 and hemi's in 68.
A lot of people are putting the 380hp crate motor in these as the only motor avalible in a 67 b cuda were the /6's and the 2 and 4bbl 273
Sounds like a cool car               lets see pictures
Offline Carlwalski
« Reply #3 on: April 14, 2005 - 01:58:46 PM »
 :iagree: Can anyone say UNDERSTEER!  :laughing: ;)
But who cares most Muscle cars were not good at cornering infact all are basically poos.
Straightline speed is where there at home.  8) :burnout: :worship: :patriot:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #4 on: April 16, 2005 - 06:22:58 PM »
I have a big block Swinger with front and rear sway bars. I would rally it with any factory big block e body and not expect to loose..
If you want a good site for your conversion check out http://www.bigblockdart.com/
2013 Tige' RZR 343hp
