Author Topic: Spacers to raise seat height on side ?  (Read 1686 times)
Offline 72cudamaan
Re: Spacers to raise seat height on side ?
« Reply #15 on: March 19, 2014 - 07:39:30 PM »
When I took out my seats to replace the carpet I found spacers made out of what looked to be plastic about 3/8" tall and 1 3/4" diameter if that helps? They were cracked so I turned up new ones in aluminum. Hope that helps? :wave:
Those sound like the stock spacers
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #16 on: March 20, 2014 - 03:56:19 PM »
:canada:
Mine were between the track and the carpet.
I guess I'm the third guy to confirm this. You definitely need some kind of spacers on the inside studs, otherwise you are tilting towards the console.
Offline anlauto
« Reply #17 on: March 20, 2014 - 04:05:43 PM »
No E Body that I've ever worked on left the factory with spacers between the seat and the floor pan.
I've never heard of a case where they were installed by the factory.
Could be a 1970 only thing, I haven't worked on too many 70's. :2cents:
Offline Racer57
« Reply #18 on: March 20, 2014 - 04:11:07 PM »
Trust me, they are needed.  After about 50miles or so my back is starting to hurt from sitting so cockeyed. But I have no idea if they were something the factory installed or if its a common problem because there is a lot of spacers made to correct it.
Offline anlauto
« Reply #20 on: March 20, 2014 - 09:28:22 PM »
I've restored 19 E Bodies to date, and parted out dozens more. NEVER had to install them in an E Body. :dunno:
http://www.alangallantautomotiverestoration.com/PAST-RESTORATIONS.html
