Author Topic: just received my passon 833 OD trans!  (Read 2326 times)
Offline halle09
« on: March 20, 2014 - 05:48:24 PM »
came in the mail today in a heavyyyyyyy crate. i was under the impression from other posts ive read that these were/ are ALUMINUM extension housings and main cases for the OD trans but i can say that it is a all cast iron case just like the original a833 (23 spline). just a fyi
Offline 73EStroker
Re: just received my passon 833 OD trans!
« Reply #1 on: March 20, 2014 - 09:16:13 PM »
Congrats. Jaimie makes a real good unit there. And not too bad on the ratios either. I had one in before I went to his new 5 speed.
Barry (Salmon Arm)
Offline SBDave
« Reply #2 on: March 21, 2014 - 02:17:22 PM »
They do offer the aluminum housings as an option.  Not sure what that would have added to the cost of a fully built transmission, but the individual parts (main case, side cover and tail housing) are about $750 on their own.
Offline halle09
« Reply #3 on: March 21, 2014 - 02:36:50 PM »
from what i read the cast iron ones are stronger and do not stretch over time like the aluminum ones so im not dragging the car. i dont mind the cast iron
Offline dakota
« Reply #4 on: March 21, 2014 - 02:43:48 PM »
Just curious - how much time between ordering it and the delivery?   I understand there's a healthy backlog in play.
Offline halle09
« Reply #5 on: March 21, 2014 - 04:55:07 PM »
backlog is for the new 5 speeds.......a833 OD i got i was told to wait 2 weeks and got it 2 weeks and 2 days...because he had to build it. And that he kept saying he was so swamped....... that sounds like a happy healthy business to me.
« Reply #6 on: March 21, 2014 - 06:52:55 PM »
I'd like to hear your feedback after you've driven it for a while.
ie: RPM/ what are your shift points, noise from gears, ease of install.
What is your final rear end gear ratioin your car right now?
Offline 67vertman
  • Member since 9-23-2005
« Reply #7 on: March 21, 2014 - 11:11:14 PM »
Yeap, he is busy building 5 Speeds..... :woohoo:  I am on that list, and have been for over a year.  :faint:
And still probably months away......oh well, the wait continues.  :popcorn:
Offline halle09
« Reply #8 on: March 21, 2014 - 11:41:23 PM »
yea ill post feedback when its ready to go. but the case is the same as my old 4 speed so it is just as easy to install as a regular 4 speed i know that for a fact.... they are extremelyyyyy simple to install or remove.
(3.55 gears from what the previous owner told me...
Offline 73EStroker
« Reply #9 on: March 22, 2014 - 11:55:23 AM »
Mine was 18 spline. And if you ever get the 5 speed it is about 1 hour to change out and be back on the road. Well maybe two with "coffee" breaks.
Barry (Salmon Arm)
« Reply #10 on: March 22, 2014 - 12:12:17 PM »
Wow. Are you an NHRA pit crew guy?  :ylsuper:  I take at least an hour just contemplating the job before I get to actual  :working:
I'd probably take a day.. ::)
Offline aris_unlimited
  • Project in full swing
« Reply #11 on: March 22, 2014 - 01:26:29 PM »
I too would like to hear a review on this once you got it installed and drive it a bit
Cuda is gone :(
74 satellite, daily driver/project now
Offline SBDave
« Reply #12 on: March 24, 2014 - 01:13:55 PM »
Just a FYI, I contacted Jamie about the weight savings of using all aluminum housings and he said they save about 34lbs and that they are fine for the street.
Offline 73EStroker
« Reply #13 on: March 24, 2014 - 08:22:23 PM »
Dodj I am what is referred to as a senior now so I have a hoist and a tranny jack. I have taken my transmission out and replaced 6 times now for differing reasons. I can now take 35 minutes to get the unit out now. If I go blind in the near future I could still make a living changing out e body manual transmissions.!!
Barry (Salmon Arm)
« Reply #14 on: March 24, 2014 - 09:29:12 PM »
He's gotta be making Bank.
Wonder how many he's churning out every week.
