Author Topic: Anyone install automatic trunk opener?  (Read 3262 times)
Offline Fern
« on: March 20, 2014 - 07:02:19 PM »
Wanting to install an auto trunk opener in chally.
Any one do this and what unit did you use?
Thanks
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Anyone install automatic trunk opener?
« Reply #1 on: March 20, 2014 - 07:55:32 PM »
Goodysgotacuda did this before on his Cuda.  Try doing a serch either by topic or by user name.  I think that's his user name.
« Reply #2 on: March 20, 2014 - 08:10:47 PM »
 :iagree:  Goody used a trunk release from a 80's Fifth Ave or Dynasty,
http://www.cuda-challenger.com/cc/index.php?topic=67750.msg695612#msg695612
« Last Edit: March 20, 2014 - 10:55:34 PM by Bullitt- »
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #3 on: March 20, 2014 - 10:39:37 PM »
I have a release from a late '70 C body, but I haven't installed it.  supposedly Gran Coupes had an optional trunk release, but I don't know where the button would have been installed. One thought was inside the center console, but I have nothing to back that up.  any knowledge would be helpful for a factory appearance!
Offline Imchallenged
« Reply #4 on: March 21, 2014 - 10:02:33 AM »
Hi;  I have one in my 70 Challenger, was in the car when I got it many moons ago.  The release button is in the glove box mounted on the top, handy but out of the way.   Info on the unit:  Lectron Products Chrysler number 4054925   60043.  It is mopar as it has the pentastar stamp on it.  In a quick search I found one on Dragtimes new for $40.00.  They say it is for a 68 to 74 Charger.  Rob
Offline Fern
« Reply #5 on: March 23, 2014 - 10:41:09 AM »
Does the trunk key also work or is it power only?
Thanks.
« Reply #6 on: March 23, 2014 - 11:07:58 AM »
Hi;  Yes it works either way. Rob
Offline Fern
« Reply #7 on: March 23, 2014 - 11:47:05 AM »
[/quote
Can you post the link to the one for sale?
Cant seem to find it.
Thanks
Offline Katfish
  • 70 Challenger
« Reply #8 on: March 23, 2014 - 11:51:24 AM »
I put the switch in the center console.  It has to be the most used upgraded I've done.
  • BP23 U0B
« Reply #9 on: March 25, 2014 - 06:57:18 PM »
That unit looks similar to mine. the levers from the external trunk lock are different with the electronic unit, so you need to remedy that aspect of it.
I like the idea of the button in the center console!  :2thumbs:
Where did you get the button?
Offline Katfish
  • 70 Challenger
Offline daveh
« Reply #11 on: March 26, 2014 - 09:52:16 AM »
I'd like to do this is this the correct latch?  Thanks
http://www.collectorcarsforsale.com/parts/69-to-74-road-runner-charger-gtx-mopar-POWER-TRUNK-LATCH-power-release-For-Sale_231186754649.html
I've searched for the Late 80's New Yorkers, 5th Aves, Diplomats and such came with electronic trunk releases that was in Gordy's post but had no luck.
Thanks for your help.
« Reply #12 on: March 26, 2014 - 10:37:02 AM »
Comparing photos of that one and the one I have  I would say that they are the same
Offline 1973JA5
« Reply #13 on: April 01, 2014 - 11:29:58 PM »
Just finished doing this to my '73 Challenger.Used a '73 C-Body latch and switch.Mounted the push button on the temperature control panel next to the rear speaker fader switch.Tapped into the hot terminal on the fuse box and put a fuse inline on the hot wire.
« Reply #14 on: April 02, 2014 - 08:33:20 AM »
I have the exact same latch on my car too. Previous owner installed it. The wire disappears up the drivers side rocker panel area. I've never tried to trace it, or found a switch anywhere? How are they wired?  If I run 12V to the wire on the latch will that be enough to test it to see if it even works? I assume ground is to the body via the latch being bolted to the body?  If it's not working are they still available new?
