you might put your calipers on both bars and see if they measure the same diameter....??
If you take them out, stand them on end so that the bottom hexes are lined up with each other...then look at the top hexes and see if they are clocked in opposite directions from one another....they should be equally clocked in opposite directions
I think we have a winner!
The bars are clocked differently. The L, my good side, the bars are 30* offset from end to end - the hexhead point on one end lines up with the center of the flat part on the other end. On the R bar, the trouble side, the hexhead is not offset - the point on one end lines up with the point on the opposite end.
Based off the previous posts they should both be 30* offset, correct? Not one one way and the other the other way?
