Author Topic: Torsion bar replacement and adjustment  (Read 17870 times)
Re: Torsion bar replacement and adjustment
« Reply #45 on: April 12, 2014 - 09:10:15 PM »
Not sure that all are 30 degs, but they should be symmetrical...looks like a mis-packaging to me
 :iagree:  The angle changes with the diameter but for sure they should be symmetrical!
Looks like a warrantee issue. At least you won't drive yourself nuts wondering why....  :grinyes:
Offline 1973JA5
« Reply #46 on: April 14, 2014 - 11:48:06 AM »
After following this thread I decided to check out the factory service manual on torsion bar installation,and this "clocking" thing.On all carlines(Dodge)this was the procedure. (1)Insert torsion bar through rear anchor.(2)Slide balloon seal over torsion bar (3)Coat both hex ends of torsion bar with multi purpose grease.(4) Slide torsion bar in hex opening of lower control arm.(5)Install locking ring,making sure it is seated in it's groove.Nothing is mentioned about clocking.I just did this job and with the exception of getting right and left correct I just shoved them in the rear mount,moved each lower control arm either up or down to align the hex end with the LCA and that's it.I had the upper control arm bumpers off,the adjuster bolt screwed in a couple of threads.After putting the bars in I cranked the adjusters to about where they were when I started and I came within a 1/2" +/- of my original ride height.
« Last Edit: April 14, 2014 - 03:46:49 PM by 1973JA5 »
Offline CudaCraig
« Reply #47 on: April 15, 2014 - 10:13:57 AM »
 :thumbsup:  That's about how my installation would have went had the supplier not sent me one bar that had a 0* offset (R) and one that had a 30* offset (L).  Prooves the importance of checking your parts when you get them.
"America is all about speed. Hot, nasty, bad-ass speed" - Eleanor Roosevelt
1973 Plymouth Cuda  477 stroker, 727, 3.55
1971 Plymouth RoadRunner, 383, 727 Slapstik, 3.55 - Sold
1965 Plymouth Barracuda "S" formula, 273 4 bbl, 904 - Sold (still regret selling)
Offline 1973JA5
« Reply #48 on: April 15, 2014 - 01:29:42 PM »
OK,got it! :woo:
