Author Topic: AAR Water Pump  (Read 1121 times)
Offline taxspeaker
AAR Water Pump
« on: March 23, 2014 - 07:14:36 PM »
Hey guys the water pump on my original 340-6 is going out. Does anyone know if the AAR used a special water pump with the TA 340 block or can I just use a standard one?
Thanks
Bob
Matching Alpine White/ Black Vinyl Top
Matching console/black interior automatic
1970 AAR Cuda (numbers matching)
1970 Superbird (unrestored)
We drive em! Watch out on I-65 in the Midwest and honk!
Offline anlauto
Re: AAR Water Pump
« Reply #1 on: March 23, 2014 - 07:39:37 PM »
Same as any other small block.
Offline Moparparts
Re: AAR Water Pump
« Reply #2 on: March 23, 2014 - 08:17:08 PM »
Get the one with 9 holes in the casting on the front surrounding the shaft it has more blades than the ones with 4 or 5 holes in the casting on the front surrounding the shaft . I have quite a few nice part numbered factory original 70 date coded 9 hole cores here if you decide you want to send an original in and have it redone PM or e-mail me
Thanks
Bob
« Last Edit: March 24, 2014 - 11:15:19 AM by Moparparts »
Re: AAR Water Pump
« Reply #3 on: March 23, 2014 - 08:54:26 PM »
AAR may have used the 6 blade impellor to increase HP , in theory they only make the 8 blade one new now so you may want to have one built for you or rebuild the original
Offline taxspeaker
Re: AAR Water Pump
« Reply #4 on: March 24, 2014 - 03:08:21 PM »
Thanks-ordering one from member moparparts
