Author Topic: Where does clock get its power ? UPDATE !  (Read 940 times)
Offline Racer57
« on: March 24, 2014 - 08:28:29 AM »
70 Rallye dash clock
Does it get its power from the alt gauge + feed or from a gauge that gets its power from the voltage limiter  ?
« Last Edit: April 03, 2014 - 10:34:17 AM by Racer57 »
Offline 72cudamaan
Re: Where does clock get its power ?
« Reply #1 on: March 24, 2014 - 08:33:01 AM »
My clock gets power from the amp gauge. But mine isn't a rallye dash so I'm not sure if it's the same.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 73EStroker
« Reply #2 on: March 29, 2014 - 04:02:52 PM »
I took mine from one of those triple red plugs that poke out of the under dash harness. That is continuous 12v power.
Barry (Salmon Arm)
Offline Racer57
« Reply #3 on: March 29, 2014 - 05:37:13 PM »
Update.....
I received a new clock from OER through Roseville. I powered it off of the alt gauge + terminal. The second hand worked perfect but the clock would lose 1/2hr in a 2hr time period. I contacted John at Roseville, who in turn contacted OER. OER is sending a new clock, but apparently they asked if my voltage limiter was good. This makes me wonder if my clock should've been powered off of it instead of the alt power.
Does anyone have their 70 Rallye clock powered off of the voltage limiter ?
« Last Edit: April 03, 2014 - 10:35:21 AM by Racer57 »
Re: Where does clock get its power ? UPDATE !
« Reply #4 on: March 30, 2014 - 01:39:27 PM »
Doesn't the voltage limiter only have voltage when the key is in the "on" position or the car is running?
It sounds like a bad clock to me.
Offline Racer57
« Reply #5 on: March 30, 2014 - 02:33:03 PM »
I hadn't thought about the limiter only having voltage with the key, which means that whoever Roseville spoke to at OER didn't know what they were talking about.
