Author Topic: lower steering column bearing not there  (Read 721 times)
Offline crash340
« on: March 25, 2014 - 03:56:53 PM »
My 73 Cuda, doesnt seem to have a lower steering column bearing, had a look from under the car and the only thing that is on the end of the outer housing is a white plastic cap, I can grab the steering shaft and move it a good 3/4" side to side :dunno: :clueless:
Greg
73 Cuda
Brisbane, Australia
Offline anlauto
Re: lower steering column bearing not there
« Reply #1 on: March 25, 2014 - 04:08:51 PM »
The white plastic cap is all they had. There is no lower "bearing" in a 70-74 E Body. :2cents:
Offline edl94
  • She Cuda
« Reply #2 on: March 25, 2014 - 04:15:35 PM »
Here is an interesting way to fix it. I have not tried it but it is on my list.
http://www.cuda-challenger.com/cc/index.php?topic=91398.0;topicseen
« Reply #3 on: March 25, 2014 - 04:20:59 PM »
I think there was originally a foam seal inside that plastic piece.  This kept hot engine compartment air from entering the steering column.  I made a new seal out of some scrap foam and reused the plastic piece on my Challenger.  I added an insert bearing to my Dart's column.
Offline anlauto
« Reply #4 on: March 25, 2014 - 06:13:34 PM »
You can actuall fit an A & B lower column bearing into a E Body column with little effort :2cents:
