Author Topic: backfiring  (Read 5153 times)
Re: backfiring
« Reply #15 on: March 27, 2014 - 06:00:32 PM »
Incorrect timing can cause backfire. You are assuming the vacuum advance is working properly.
I agree with you on the incorrect timing part.
When you nail the gas pedal, your vacuum advance will be at zero. So that's why I think the problem is elsewhere.
Offline cudabob496
Re: backfiring
« Reply #16 on: March 27, 2014 - 08:23:20 PM »
Yes, the vacuum advance will be zero, if it is working properly. My old Mopar vacuum advance would
not always go to zero, so I ended up chucking it.  So to eliminate the possibility of the vacuum advance
being a problem, I suggested unhooking it.
2011 Kawasaki Z1000
Re: backfiring
« Reply #17 on: March 28, 2014 - 04:05:53 PM »
Wow!
 OK, I see what you are saying now. Just be sure to plug the carb. port, or you will be sucking in air.
Offline cudaaah
  • 71 HEMI cuda, 2015 ram 2500 mega cab diesal 4x4
Re: backfiring
« Reply #18 on: June 21, 2014 - 08:49:23 PM »
Haven't been on the site for awhile, obviously.  To update, I took the car to my engine builder. After putting new ignition parts in, timing was good, carbs good,  it was still backfiring.
Finally checking the distributor itself, he found a small brass tab broken off inside the distributor itself, I seem to remember him saying it had something to do w/ the timing advance.  Heand said it looked like someone had shoved a screw driver in.  Needless to say I made a mistake going to the local "EXPERT".
Thanks all for the help
Live and learn...there's an expert in every garage :horse:
Offline cudabob496
Re: backfiring
« Reply #19 on: June 21, 2014 - 09:58:38 PM »
Good to hear! Timing may have been good at idle, but should be checked throughout the rpm range.
2011 Kawasaki Z1000
