Author Topic: Lost a lash cap on my 340, now what?  (Read 11348 times)
Re: Lost a lash cap on my 340, now what?
« Reply #45 on: April 02, 2014 - 08:17:48 AM »
I actually suggested the springs could be bad or too light for the application earlier , anyway glad you found the problem , I would still run the lash caps . With the springs being to light the valves could have been late closing allowing slack between the rockers & valves causing them to hammer into the rocker arms instead of staying in contact at all times so the rocker failure was more likely to be effect not cause .
Offline 72bluNblu
« Reply #46 on: April 02, 2014 - 01:09:50 PM »
Sorry Neil! You sure did. I've got a couple threads going on different forums, I have a hard time keeping them straight sometimes. Your help is greatly appreciated!  :2thumbs:
Obviously I'll be taking a look at the geometry again with the new rockers, but I don't think I'll need the lash caps with the Crane's. The Harland's are spec'd for taller valves, I don't think the Crane's are. But I'll have to go through all of that again when I get the heads back, checking the pattern and measuring for push rods. My machinist is going to correct the valve height's, so I'll have to see how that turns out. It'd be nice not to have to order new push rods. But it'd be a lot nicer not to destroy another set of rockers, so I'll remeasure everything and see what I get.
I would have thought that the hydraulic lifters would have made all of this a bit easier, it's amazing that the factory could just slap on non-adjustable rockers, hydraulic lifters, and pretty much the same height pushrods on everything despite the range of build tolerances they had. But this was my first build, and although I tried to get everything right the first time its obvious I still have a few lessons to learn. Fortunately I went a different route with my second build by doing all of the assembly myself and using RHS heads, but you'd better believe I'll be double checking everything on it before it gets dropped in.
« Last Edit: April 02, 2014 - 01:12:08 PM by 72bluNblu »
Offline 7212Mopar
« Reply #47 on: April 02, 2014 - 01:46:56 PM »
I am planning to do the top end on my 340 with Edelbrock RPM heads, hydraulic roller setup from Hughes and a Howards hydraulic cam after summer. I have done a lot of reading about the subject and will be taking little careful steps on this since I never replace heads and valve train before. Now reading what happen to yours I am getting cold feet and having second thought  :-\
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline cudabob496
« Reply #48 on: April 02, 2014 - 06:33:25 PM »
Why not let someone like Huges just set up your entire heads/valve train, and use their recommended components.
2011 Kawasaki Z1000
Offline 7212Mopar
« Reply #49 on: April 02, 2014 - 08:04:52 PM »
Mainly $ issue. Lets just get back and stay with the OP's post which I will for sure be following to see how things turn out and hopefully learn a few things.
« Reply #50 on: April 02, 2014 - 08:07:57 PM »
Personally I would use different heads like RHS , the core shift I have seen with the eddy heads is horrendous to say the least
Offline cudabob496
« Reply #51 on: April 02, 2014 - 08:38:07 PM »
what does core shift mean?
2011 Kawasaki Z1000
« Reply #52 on: April 02, 2014 - 08:41:27 PM »
Neil, have you worked with those Airwolf heads before? They look like the hands down winner for a SB?  :dunno:
I'm dreaming of a set of these and an aluminum block! :drool:
http://www.j-performance.com/index.php?option=com_content&task=view&id=59
« Reply #53 on: April 02, 2014 - 10:24:39 PM »
No , I have never worked with the airwolf heads , look good though !
Core shift means when cast nothing is in the correct place , the ports can be 1/4" off side to side & porting to line them up could put you into a water jacket , a friend bought Eddy heads but worked at the performance store & took his pick from 10 sets & he showed me some of the bad ones , very shoddy QC
