Author Topic: New hoses and fluid for std brakes  (Read 1759 times)
Offline crash340
« on: March 26, 2014 - 03:19:39 PM »
Team of wise ones.
Two questions.
Q1. What type and where to go for the best replacement flex brake lines please. two front, one rear. Car is a 73 Cuda, street/stip
Q2. time to replace the old fluid,,,,,,with what!. I see a lot of DOT series options, silicon bla, bla. and given its more than likely old fluid, is it just a matter of draining as best I can and pumping new fluid through until I see new fluid out the bleed nipples?????
Thanks
Greg
Greg
73 Cuda
Brisbane, Australia
Offline anlauto
Re: New hoses and fluid for std brakes
« Reply #1 on: March 26, 2014 - 03:27:30 PM »
If you're on the strip, you might require braided steel flex hoses :dunno:
I use Dot 5 on all my restos
Offline crash340
« Reply #2 on: March 26, 2014 - 03:43:30 PM »
Thanks Alan, its not a specific requirement out here but its not beyond my thoughts though, will need to justify it.
Your resto's will have all the lines flushed I assume as you will have them all off the cars, im not pulling them off the car so getting the old fluid out seems like all I can do is just flush it via topping up the master cyl and pumping it though, how will effect going to the new regarding contamination etc, if any
Greg
73 Cuda
Brisbane, Australia
Offline anlauto
« Reply #3 on: March 26, 2014 - 03:53:58 PM »
I've sprayed "brake-clean" through each line one at a time to remove old fluid.
One idea I had, but never tried, would be to fill the master with "brake-clean" and just open the bleeders and keep pumping it through :dunno:
« Reply #4 on: March 26, 2014 - 08:36:30 PM »
I use Raybestos first Wagner is good too , Contact Rock Auto
 I only use Dot 5 also
Offline Strawdawg
    • Vortex Buicks
« Reply #5 on: March 26, 2014 - 09:29:38 PM »
I think brake clean will ruin all the seals it comes into contact with
Steve
Offline 72cudamaan
« Reply #6 on: March 27, 2014 - 12:48:42 AM »
Steve
Should be okay if he uses the non chlorinated Brake Kleen
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Strawdawg
    • Vortex Buicks
« Reply #7 on: March 27, 2014 - 12:50:02 AM »
Only if that type has no alcohol in it
Steve
Offline crash340
« Reply #8 on: March 27, 2014 - 01:15:34 AM »
Thanks guys , all good info, what about hoses, who makes the best or at least good, what is the recomendation
Greg
73 Cuda
Brisbane, Australia
Offline jhaag
« Reply #9 on: March 27, 2014 - 01:11:41 PM »
Raybestos or Wagner make good OEM style replacement parts. Should be easily found from your local auto parts store.
love 70 Challengers
« Reply #10 on: March 27, 2014 - 01:22:33 PM »
I bought everything from CARQUEST.(front/rear hoses and DOT5 fluid)
Offline crash520
« Reply #11 on: March 27, 2014 - 06:02:59 PM »
I need somewhere online, we dont have those places out here :aussie:
Daves Autoparts have a good selection at a great price by the looks.
Greg
« Reply #12 on: March 27, 2014 - 08:49:12 PM »
Read above
Rock auto, use  Raybestos or Wagner hoses
Offline crash520
« Reply #13 on: March 27, 2014 - 10:06:58 PM »
thanks CP
Offline crash340
« Reply #14 on: March 28, 2014 - 07:21:00 PM »
CP, new hoses and seal kits etc purchased from Rockauto. Shipping to Au was $100, I had them shipped to my Daughter in TN, she will throw them in a pre paid box with other stuff for me and ship 20Lb to me for $65 so all good.
Greg
Greg
73 Cuda
Brisbane, Australia
