Author Topic: Installing engine and transmission question?  (Read 12121 times)
Offline Mpdlawdog
Re: Installing engine and transmission question?
« Reply #15 on: March 28, 2014 - 09:04:55 AM »
For years I used the base of this type engine stand (see photo).
Sometimes it was a little too wide to get my engine hoist around so I made a similar looking four wheel frame, just a little narrower
 :thumbsup:  Thanks!  Easy enough!
« Reply #16 on: March 28, 2014 - 09:13:15 AM »
I used snowmobile pads , 3 of them 1 under each side of the K frame & one under the tail of the trans to roll it underneath the body , each pad had 4 castors on it
Offline Mpdlawdog
« Reply #17 on: March 28, 2014 - 10:18:16 AM »
do you mean like this??
http://www.ebay.com/itm/WelBilt-Snowmobile-Dollies-Set-of-3-1500lb-Cap-404550-/281200467458?pt=LH_DefaultDomain_0&hash=item4178da9e02
Offline HP_Cuda
  • Mopar or No Car!
« Reply #18 on: March 28, 2014 - 11:55:47 AM »
I agree that the stand you use will have to be narrow, low and able to move in four directions is a plus.
The lower the better as well, you don't want something high off the ground as it will only make you jack the car higher.
Last but not least it needs to support the tranny at the rear.
Good luck! :2thumbs:
Offline cudabob496
« Reply #19 on: March 28, 2014 - 12:50:58 PM »
I guess there is no reason other than we have never done it. Would I just need an engine hoist? Also the fenders are on the car which I do not want to remove. Can I still lift the car without removing the fenders?  Thanks
On a different note, I use to ride a 750-H2. Crazy fast, for its time.
2011 Kawasaki Z1000
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #21 on: March 28, 2014 - 09:19:19 PM »
A little off subject here,  but,
Can this be done with an A body barracuda?
« Reply #22 on: March 28, 2014 - 09:29:20 PM »
Yes virtually every engine was installed this way from the factory except maybe some of the Max Wedge where the engine would be still installed the same way but I am not sure the manifolds would clear !!
Offline HP_Cuda
  • Mopar or No Car!
« Reply #23 on: March 28, 2014 - 10:19:09 PM »
A little welding with those dollies could turn out to be a pretty nice setup and reusable!
 :2thumbs:
Yes  :2thumbs:
« Reply #24 on: March 28, 2014 - 11:19:27 PM »
I probably installed 20+ engines with the set I bought .
 Yes the car can be lifted with the front sheet metal all in place
Offline Mpdlawdog
« Reply #25 on: March 29, 2014 - 12:29:03 PM »
 :wave:
Yes  :2thumbs:
Just ordered them...great idea!!  Did you make any mods on them??   I assume they can handle the weight since it's evenly distributed
Offline Mpdlawdog
« Reply #26 on: March 29, 2014 - 12:31:40 PM »
Don't be scared ;) I had never done one before either....it was easy!!  And trust me I'm no mechanic.....
Offline Strawdawg
    • Vortex Buicks
« Reply #27 on: March 29, 2014 - 04:06:44 PM »
I do it from the bottom , far faster & the engine trans & suspension goes in virtually complete except for the rad & fan shroud & maybe the fan !
 I have lifted the front of the car with my legs , place 2 stands under the front spring eye & use the diff weight to counterbalance the nose & it is only approx. 150 lb lift , roll the k with the engine & trans under , lower the nose & start the K frame bolts , easy !!!
Neil, do you remove the rear tires, or do you just get the jack stands tall enough to allow enough "pivot"?
« Reply #28 on: March 29, 2014 - 04:38:00 PM »
rear tires stay on.
« Reply #29 on: March 29, 2014 - 06:32:31 PM »
Good stuff.
