Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
Tach wire thru firewall on 1973 Challenger
« previous
next »
Print
Pages: [
1
Author
Topic: Tach wire thru firewall on 1973 Challenger (Read 769 times)
FCC
Jr. Member
1973 Dodge Challenger 340
on:
March 27, 2014 - 02:02:15 PM »
I have a gray/black stripped wire going through a hole in my firewall next to the brake booster. This is the only wire going thru that hole and there is no grommet. I believe this is the tach wire that goes to the negative side of the coil. A female bullet connector is on the end of the wire. I replaced the factory engine wire harness with a M&H harness.
My question is... was there a factory grommet that was used? The wire goes thru the firewall and inside behind the fuse panel. I can't seem to find any repro grommets or mention of how the factory did it. Thanks.
Logged
burdar
Sr. Resident
Re: Tach wire thru firewall on 1973 Challenger
Reply #1 on:
March 27, 2014 - 02:09:12 PM »
Yes, there is a grommet and yes it is the tach wire. If I remember correctly, my new M&H harness came with a grommet already on that wire.
Logged
FCC
Jr. Member
Reply #2 on:
March 27, 2014 - 06:15:12 PM »
Thanks Burdar! My M&H did not include the tach wire. I know they sell it separately for earlier years that plugs into the harness. Do you happen to have a part number? Thanks.
Logged
burdar
Sr. Resident
Reply #3 on:
March 27, 2014 - 06:52:32 PM »
My new main dash harness had the grommet already attached to the tach wire. There is a short (6" maybe) wire that goes from that wire to the coil. I don't know if that grommet is included in the body plug kits or not.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
