Author Topic: AllPar article gets it wrong?  (Read 1816 times)
Offline KZ
« on: March 27, 2014 - 03:34:13 PM »
On AllPar's website there is an article written by Richard EHRENBERG   http://www.allpar.com/mopar/440.html   on the history of the 440 6-pack motors. "They ordered a trio of Holley's best centerhung-float 2300 deuces, totalling 1,200 cfm".
Correct me if I am wrong, but the 6-pack setup has a 350 cfm center carb, and the 2 outboard carbs are 500 cfm each, if my math is right that is 1350 cfm, not 1200. I would expect non-Mopar related webpages to be misinformed but one would think a website that goes by the name ALLPAR would have caught this. Seems like sloppy editing to me.
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
Re: AllPar article gets it wrong?
« Reply #1 on: March 27, 2014 - 03:50:37 PM »
I thought it was the opposite, 500 cfm center and outers were 350cfm each, making 1200.  But I'm no expert
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline CudamanTom
« Reply #2 on: March 27, 2014 - 04:15:31 PM »
That sounds about right. You want the higher CFM on the center carb.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline Joe mama
« Reply #3 on: March 27, 2014 - 04:18:58 PM »
The center is a 350 and the outers are 500's
73 Challenger, 440+6, 5 speed Tremec, Dana 60
Offline anlauto
« Reply #4 on: March 27, 2014 - 04:27:57 PM »
Yep :iagree:...Straight from the horses mouth..http://www.holley.com/0-4144-1.asp .
Offline anlauto
« Reply #5 on: March 27, 2014 - 04:28:50 PM »
If you read it on the Internet....It has to be true... :roflsmiley:
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #6 on: March 27, 2014 - 04:33:52 PM »
Were the carb sizes the same for the 6 pack small blocks?
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline anlauto
« Reply #7 on: March 27, 2014 - 04:40:47 PM »
Yes, just jetted differently :2cents:
Offline jordan
« Reply #8 on: March 27, 2014 - 06:02:13 PM »
I have read (probably on this site) that 2bbl carbs are measured differently than 4bbl carbs for air flow rates.  Though they are claimed to add up to 1350 cfm, the actual rates are really closer to 1200 cfm.  I don't have the science to reference to, so believe what you want.  J
Offline Strawdawg
    • Vortex Buicks
« Reply #9 on: March 27, 2014 - 08:06:01 PM »
Divide the two barrel rating by 1.414 to get approximately the 4 barrel rating
Steve
« Reply #10 on: March 27, 2014 - 08:30:00 PM »
There is a disparity , the 2 bbls are rated @ 3" vacuum
4 bbls are rated at 1.5" vacuum so the smaller 2 bbls do not flow as much as it would seem if compared to a 4 bbl so I have typically heard the 6 pack flows approx 900-950 CFM at 1.5" of vacuum
Offline AARuFAST
  • AARuFAST
« Reply #11 on: March 28, 2014 - 02:54:29 PM »
NOPE 440 carbs 6 pack will not fit on the 340 manifold.
Throttle plates are larger on 440.
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline anlauto
« Reply #12 on: March 28, 2014 - 03:30:48 PM »
Really ? News to me ... :dunno:
Offline teslasbrain
« Reply #13 on: March 28, 2014 - 10:55:32 PM »
Alpar still thinks that J heads only came on 340 6pack engines in 1970.   :screwy:
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #14 on: March 30, 2014 - 10:59:44 AM »
Could be a typo or E Booger correcting it to a real number that people would understand as the 2bbl carbs are rated differently as mentioned already.
2013 Tige' RZR 343hp
