Author Topic: SHOCKS!!  (Read 7923 times)
Re: SHOCKS!!
« Reply #15 on: May 30, 2014 - 09:40:43 AM »
I just bought a set (4) of Hotchkis adjusted Fox shocks for one of my customer's cars that wanted a "better then stock" ride.
For the same price as my customer paid for the four Hotchkis shocks....I could have bought 39 of the Monroe shocks :22yikes: no lie... :smilielol:
Its all relative to whats important to the user. In your restorations, do you use officially license reproduction lenses with the correct stampings and part number for $500 a pair or some offshore plastic piece that fits with no numbers for $100 a pair?
Some competition shocks will be cost as much for a single dampener as your customer paid for all four of his Fox shocks. Different strokes and all.
Like 72bluNblu said, it is part of a system and you want to make it all work together.
« Last Edit: May 30, 2014 - 09:42:38 AM by HP2 »
Offline Mopar Mitch
Re: SHOCKS!!
« Reply #16 on: May 30, 2014 - 10:37:21 AM »
You'll get what you pay for with shocks.   Adjustables offer the best driver choice, and can better match up to your suspension and driving style, but you pay more more for them.  I've KONI (red) in my Challenger... adjustable.
Offline wiging19
Re: SHOCKS!!
« Reply #17 on: June 06, 2014 - 10:48:35 PM »
I was waiting to see if anyone mentioned Koni shocks.  Growing up those were the shocks my friends put in their cars.  Now there are other good choices to pick from.  For nostalgic reason's I like Koni.
Offline sbrinsky
Re: SHOCKS!!
« Reply #18 on: June 08, 2014 - 01:19:40 PM »
I have a 1973 Cuda. Nothing has been changed customize wise, no lift kits and etc.... it is possesses the standard rally package.
The springs have recently bee re arched back to factory.
I am looking to replacing the front and rear shocks. I am hoping some one can provide me with the specification of shocks required.
What are the dimensions (length) required for the front and rear shocks? I assume shocks go by a extended/retracted length?
Are the bolt hole sizes standard, meaning will a 2014 shock (Ie Monroe, KYB etc..)   fit or is a special order required?
Thanks in advance.
sbrinsky
Offline gafletch
Re: SHOCKS!!
« Reply #19 on: June 08, 2014 - 05:36:37 PM »
Co-worker went with Bilstiens on his pickup. Loves 'em.  They have a plant in my town but they don't make ones here for ebods. German company, well engineered .Bilstien/RCD makes 'em for e's. Saw them on eBay. If my adjustable drag shocks can't be made to ride better I'm going with B/RCD. About $100 each.  :working:
Re: SHOCKS!!
« Reply #20 on: June 09, 2014 - 08:21:09 AM »
You will never get a good handling street car with drag shocks. That's not what they were designed to do. I would order the Bilsteins, not the stock monroes. I replaced monroe stock type with $80 a piece Edelbrock IAS shocks and was amazed at the handling improvement. Particularily when the road has a lot of small bumps, the Challenger used to get a "little" loose. The IAS shocks now have the rear holding the road much better. The IAS shocks aren't available anymore but the Bilsteins are reportedly better.
Offline HP_Cuda
  • Mopar or No Car!
Re: SHOCKS!!
« Reply #21 on: June 10, 2014 - 02:30:34 PM »
As long as we are talking drag shocks, I was going to replace all four corners in my Yellow Cuda and hit some snags and only replaced the front shocks with Bilsteins and WOW the front end of the car feels like you can really control it compared to the POS drag shocks that were in it before which made it ride like a freaking tank.
Can't wait to replace the rears and while I'm at it I will replace the Blue fuel pump with a Red one since it's overkill.
B
Offline stinger
Re: SHOCKS!!
« Reply #22 on: June 10, 2014 - 06:54:00 PM »
my Monroe's suck,bottomed out on my exhaust doing 40 with just a slight dip in the road.ofcourse my car sits a bit on the low side.
