Author Topic: Another shock question  (Read 564 times)
Offline blown motor
« on: March 27, 2014 - 10:31:07 PM »
I have GasAdjust shocks on my car. I want to lift the back end about 3/4". Can I do it with another shock?
Offline Rich G
Re: Another shock question
« Reply #1 on: March 27, 2014 - 11:52:30 PM »
The only shock going to lift a car is an air shock.
« Reply #2 on: March 28, 2014 - 07:13:44 AM »
 :iagree:  As far as I know anyhow? Not a good way to lift the rear either. The structure that the shocks mount to was never designed to support the weight of the car.
Offline bigblue73
« Reply #3 on: March 28, 2014 - 08:44:53 AM »
Search on this site
"Re-arching rear springs"
and
Add a leaf"
I chose to replace mine all together, but some folks here have alternatives to total replacement.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #4 on: March 28, 2014 - 08:51:28 AM »
 :iagree:  Can't lift a car with a shock unless it's an air shock or maybe a coil over shock but as Brad mentioned that shock mount wasn't meant to carry that weight.  I heard stories of old Camaros with air shocks that when the shock mounts rusted and broke you could loosen the upper shock bolts from inside the trunk.  :roflsmiley:
I used a full length add a leaf as bigblue mentioned on an old 5th Ave years ago and it did get a little lift in the rear and wasn't too expensive.  The car handled better as well.  I don't see the full length leaves in the stores now but imagine you can order them. Not sure if there is a down side to those though.
Offline anlauto
« Reply #5 on: March 28, 2014 - 08:58:27 AM »
Back in the day we used to install a "Load Leveler" Shock. I think that would give you the 3/4 extra lift you're looking for without the issues associated with air shocks. :2cents:
« Reply #6 on: March 28, 2014 - 09:07:11 AM »
the shock crossmember is strong enough to allow the shock to cycle without taking any weight , any shock that lifts the car at all will transfer weight from the spring perches to the shock crossmember which is not a good idea . The only shocks that lift the rear are weight bearing like the coil over type or air shocks , anything else gas type or basic hyd will not lift the car at all . To properly lift the rear you can add a leaf or replace the springs .
Offline blown motor
« Reply #7 on: March 28, 2014 - 09:12:57 AM »
Thanks guys. I'll start a new thread on springs.
