Author Topic: 73 cuda new hood opinions/options  (Read 678 times)
Offline Walls73
« on: March 29, 2014 - 12:17:25 PM »
I have a 73 cuda 340 with the twin bulge hood. But the problem is that it won't fit due to how my motor is set up. So was looking at ideas for a new hood. And most likely will be turned into a fresh air set up. Any ideas or pictures are greatly appreciated!
Offline anlauto
Re: 73 cuda new hood opinions/options
« Reply #1 on: March 29, 2014 - 12:21:45 PM »
Maybe an AAR Cuda hood :dunno:
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #2 on: March 29, 2014 - 12:29:21 PM »
You could use a 6pack hood, or US body source makes a 4 inch cowl induction too
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #3 on: March 29, 2014 - 12:29:56 PM »
An AAR hood
Or
A shaker hood set up.
Or
 you could get a flat hood, cut a hole,  and put any scoop you want on it.
Offline Walls73
« Reply #4 on: March 29, 2014 - 01:41:36 PM »
Yea I considered a shaker set up but so dang expensive! But leaning towards an aar hood I believe, sucks I have to use my original hood as a garage ornament but I guess it has to happen. Gonna keep scanning the internet on ideas and ways to go about it. I appreciate it though guys
Offline Walls73
« Reply #5 on: March 31, 2014 - 12:45:16 PM »
How much higher does the aar hood come up over the twin bulge hood? I'm gonna try and go that route, but want to take some measurements to be sure it will fit before I order a new hood.
Offline mopar jack
« Reply #6 on: March 31, 2014 - 01:13:19 PM »
Go with a flat hood and a demon scoop.
« Reply #7 on: March 31, 2014 - 01:47:01 PM »
What's your engine set up?  How much extra room do you need to get the stock hood to fit?
Offline Walls73
« Reply #8 on: March 31, 2014 - 02:39:28 PM »
It's a 340 and I have an rpm air gap with a 1inch spacer on it, I took the spacer out due to clearance but then my butterfly's on the carb hit the intake. So I bought a drop base air cleaner hoping that'll fit. But still won't happen. I haven't measured exactly yet, but from eye balling across my fender, it looks like the top of the air cleaner is 1 inch or maybe a bit more above the fender.
« Reply #9 on: March 31, 2014 - 02:48:37 PM »
What carb are you using?  My secondaries hit the intake as well.  It turned out to be bad core shift in the intake.  Edelbrock sent me a new one.  I'd see about having a machine shop clearance the intake so you don't have to run the spacer.
Offline Walls73
« Reply #10 on: March 31, 2014 - 02:51:47 PM »
It's a quick fuel 650 mech sec. But when I took my spacer off before the hood still pinched down on my cleaner lid.
