Author Topic: six pack spacers  (Read 820 times)
Offline mopar jack
six pack spacers
« on: March 29, 2014 - 01:06:22 PM »
Just installed a six pack on my 440 and it gets a little heat soak after running. Looking for 1/4 inch carb spacers to help isolate from the manifold. Looking for info but can't seem to find any. Have a shaker hood so can't go higher, thanks.
Offline anlauto
Re: six pack spacers
« Reply #1 on: March 29, 2014 - 01:21:05 PM »
How about 1/4" thick composite type gasket  :dunno: I've seen them for Theromquads...
Offline mopar jack
« Reply #2 on: March 29, 2014 - 01:53:50 PM »
Composit would work. I've searched fel pro and federal mogal and they show a 1/4 inch gasket but when I ordered them  they were paper thin. Thanks
Offline ragtopdodge
« Reply #3 on: March 29, 2014 - 06:50:02 PM »
DO you have an aluminum manifold or cast iron?
Painted or not painted?
WOnder if any of the above would make a difference or not.
Perhaps pull the intake and block off the heat crossover?  Won't help much w/cold starts/choke, but at least the car will run.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #4 on: March 29, 2014 - 07:09:34 PM »
Block the crossover
 The Fel Pro 1215 is blocked as supplied just install it .
 The second option is to install a thin sheet metal plate under the carbs to reflect the heat , 1/8 thick & effective .
Offline mopar jack
« Reply #5 on: March 29, 2014 - 07:24:00 PM »
Cross over is blocked and it's aluminum non painted. Allways used a phenolic spacer on the four barrel and it helped. Went to a cruise yesterday and got home after sunset, probably 65 degrees outside and when I put it in the garage I could here the gas perculating. Touch the manifold and it's real hot and the carbs are hot. I think some spacer/insulators would help.
Offline cuda346pk
« Reply #6 on: March 31, 2014 - 05:13:59 PM »
I have same problem on my small block. I bought phenolic 1/2" spacers off ebay but couldn't get them to work as they kept crushing slightly in corners as I torqued carbs down. Even the slightest tightening would cause throttle shaft to bind. Guy at promax carbs said the only material he has any luck retaining thickness is delrin. I plan to make some myself soon.
Sent from my SM-N900V using Tapatalk
David - In Georgia
1972 'Cuda In-Violet 340 6 Pack 4 Speed 3.91 Sure Grip - Finally, after 27 years of waiting and dreaming it is real. Now the fun begins!
