A518 vs TF727 RPM/Gear Ratios Chart
Author Topic: A518 vs TF727 RPM/Gear Ratios Chart  (Read 823 times)
Offline ff6849
« on: March 30, 2014 - 02:48:24 PM »
I built this chart to compare the A518 to TF727 hope its helpful if your thinking about about the conversion.
« Last Edit: March 30, 2014 - 02:49:55 PM by ff6849 »
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Offline Katfish
  • 70 Challenger
Re: A518 vs TF727 RPM/Gear Ratios Chart
« Reply #1 on: March 30, 2014 - 03:56:10 PM »
Ah Excel, my favorite MS tool.
I'm in the process of the conversion, easy math you can do in your head.
Since the OD reduces the RPMs by ~30%,  just take 10% of your current RPM, multiply by 3, then subtract.
Say you turn 3000rpm now,
10% of 3000 = 300
300 x 3 = 900
3000 - 900 = 2100 rpm
All independent of tire or gear ratio
Offline ff6849
« Reply #2 on: March 30, 2014 - 11:33:51 PM »
I am too getting ready to install one, I think I am liking the 3.91 with A518 seems to provide the best all around set-up. Your final gear ratio is 2.70, I currently have 2.76 rear gear and like it very much on the highway.
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
Offline Katfish
  • 70 Challenger
« Reply #3 on: March 31, 2014 - 01:23:32 PM »
I have 3.73s now, wish I would have stayed with the 3.55s
Modern low profile tires are shorter than the old 15 sizes.
I have 275/40/18s in the back, only 26" tall.
Offline 360FISH
  • BS23H3B567746
« Reply #4 on: April 01, 2014 - 12:44:37 AM »
I'm running the 3.73 gear and it's been great for long cruises with the 518 OD and still has pop off the line.   :burnout:
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
