Author Topic: I'm sure the Dealership would have done their dash caps the same way.  (Read 2253 times)
Offline anlauto
Re: I'm sure the Dealership would have done their dash caps the same way.
« Reply #15 on: April 12, 2014 - 08:54:55 AM »
A dash cap gets glued on top of the old dash pad. Replacement dash pads are available that replace the entire pad, metal frame and all. :2cents:
Offline CudamanTom
« Reply #16 on: April 12, 2014 - 09:02:49 AM »
ummm so I got a new dash pad no old dash pad on frame so it just gets glued down? its a dash pad and not cap that is a difference right?
I would be curious to where you got the dash pad without the frame. All I saw where dash caps (around $100) or a complete dash pad installed on plastic or metal frame (around $1000). But not a dash pad alone.  :clueless:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline 6771plymouth
  • john
« Reply #17 on: April 12, 2014 - 11:31:21 AM »
my dash pad has threaded studs on it so I bolt it on not sure most of the stuff looks like it came from r.e.m. this all new to me so ill try and get it right. I have what alan said frame and all
« Last Edit: April 12, 2014 - 11:35:49 AM by 6771plymouth »
Offline CudamanTom
« Reply #18 on: April 12, 2014 - 12:25:11 PM »
Ahhh, okay. That explains it.
Thanks,
