Hose route for the gas tank vapor container
Author Topic: Hose route for the gas tank vapor container  (Read 5360 times)
Offline Chlngrcrzy
« on: April 01, 2014 - 10:39:12 PM »
I have the vapor canister in the back, in front of the gas tank. Has the 4 small hoses that connect to the gas tank. Where does the his run that connects to the top of the small canister?
Offline cudabob496
Re: Hose route for the gas tank vapor container
« Reply #1 on: April 01, 2014 - 10:56:23 PM »
I think on my 72 it ran along the passenger side, up front, to a charcoal canister in the engine bay,
but its been a bout 20 years since I tore all that stuff out.
2011 Kawasaki Z1000
Offline Chlngrcrzy
« Reply #2 on: April 02, 2014 - 09:17:28 AM »
Yeah, me too. I wonder if i could just plug it off?
Offline 72cudamaan
« Reply #3 on: April 02, 2014 - 09:34:27 AM »
You could, but it is your tank vent. Might have some problems. It still works even if it's not connected to a
charcoal canister.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline blown motor
« Reply #4 on: April 02, 2014 - 09:49:40 AM »
Andy, mine was still sticking up in the front corner of the engine bay even though the cannister was gone. We clipped it off under the car with a side cutter and got rid of it to tidy things up a bit under the hood. Is this going to be a problem?
Offline Chlngrcrzy
« Reply #5 on: April 02, 2014 - 09:57:14 PM »
Any ideas where to buy the cheapest canister? Autozone sell these things?
Offline cudabob496
« Reply #6 on: April 02, 2014 - 10:14:47 PM »
I'd make it out of 2 or 3 inch PVC pipe and some aquarium charcoal.
2011 Kawasaki Z1000
Offline 72cudamaan
« Reply #7 on: April 02, 2014 - 10:38:12 PM »
I would probably make sure it points down so as not to pick up moisture but as long as the tank has a vent you
should be okay. On the other hand I suppose a vented gas cap would work as well. Also keep in mind that the termination
 point on the vent hose should be higher than the gas tank to prevent a siphon effect.
Offline jmkdopkins
« Reply #8 on: April 13, 2014 - 08:12:37 PM »
I need to replace the leaking gas tank on my 1973 Cuda 340.  My new replacement tank will have the 4 vents on the front of the tank. But looking at my car, the old tank has 1 vent on the side of the tank and its hose runs into the engine compartment. The hose just vents into the engine compartment and not into a canister. So it appears I don’t have the original gas tank or vapor canister.
The previous owner did this to prevent vapor lock.
So after I install the new tank, it sounds like I can run one vent into a canister. I don’t think you can buy a replacement canister.   So can someone give me some greater details on how to build a canister?   I thought I would mount it in the engine bay.
Thanks.
Offline plumcrazzy
« Reply #9 on: April 13, 2014 - 08:25:01 PM »
Are you guys referring to the tank vent or the fuel return line? My '70 440 Six-Pack has a vapor extractor below the fuel pump that is supposed to help prevent vapor lock. This canister used to be available aftermarket (Year One I think). :burnout:
Offline jmkdopkins
« Reply #10 on: April 13, 2014 - 08:50:15 PM »
Thanks.  Year One does have vapor separators that mount between the fuel pump and carburetor for 440's, but I am talking about a vapor canister that the tank vents into.
I just saw another thread on this site, and it sounds like I could just plug all the tank vents and get a venting gas cap.  If that works, that is a much easier solution.
Offline 72cudamaan
« Reply #11 on: April 13, 2014 - 09:35:25 PM »
Thanks.
That won't do anything to change vapor lock. The vapor separator with a return line does that.  Just sayin  :bigsmile:
Offline 72cudamaan
« Reply #12 on: April 13, 2014 - 09:38:26 PM »
If you want one, you can find the vapor canisters on ebay most of the time. I don't now with certainty if a
vented gas cap will produce the same results or not.
Offline jmkdopkins
« Reply #13 on: April 14, 2014 - 05:34:59 PM »
Thanks guys for the responses.  I will start looking on eBay for a vapor canister.
In the meantime, I think I will use a vented gas cap.  My understanding is that a vented gas cap will allow air into the tank.  Now the car runs great now, but I don't like my current set-up of a venting into the engine bay with nothing on the end of the hose.  So I am hoping the vented gas cap will work.
Offline Chlngrcrzy
« Reply #14 on: April 14, 2014 - 10:13:06 PM »
I found my old canister and the mounting ring. Where exactly is it mounted and where can i find that plastic vent that goes on the end of the vent hose? There are 3 lines going to the canister, i assume 1 is from the tank, 1 is the vent line and the 3rd is ?
