Author Topic: New Wilwood brakes  (Read 963 times)
Offline soundcontrol
New Wilwood brakes
« on: April 02, 2014 - 05:13:10 AM »
I ordered new Wilwood brakes, front ant rear, with a new Wilwood master cylinder, will I need an adjustable valve for the rears?
/ Ken
topic=108917.new#new
Offline hemiken
Re: New Wilwood brakes
« Reply #1 on: April 02, 2014 - 06:06:39 AM »
Sometimes Yes and sometimes no. But it is good reassurance to have it if it needs fine tuning, so it would be best to fit one in your line anyway. :2thumbs:
Offline anlauto
« Reply #2 on: April 02, 2014 - 06:54:13 AM »
It is recommended :2thumbs:
« Reply #3 on: April 02, 2014 - 07:03:21 AM »
OK, thanks, I'll order one.  Can this one be used?
http://www.summitracing.com/int/parts/wil-260-11179/relatedkitscombos
I guess the ins and outs for the fronts are just a split with no adjustment, and the electrical
connection is a brake light switch.
/ Ken
Offline hemiken
« Reply #4 on: April 02, 2014 - 07:06:12 AM »
You actually only need one with a single inlet and single outlet if you want, this will cut off pressure to the rear to make the system equal. But if you do not have a brake block to split the lines for each corner, then the one you posted would be the one needed. :2thumbs:
Offline anlauto
« Reply #5 on: April 02, 2014 - 07:28:05 AM »
that's the one I've used
« Reply #6 on: April 02, 2014 - 07:46:39 AM »
I used just the wildwood valve posted above in my combo, but never needed it. It's always been wide open.
« Reply #7 on: April 02, 2014 - 08:10:43 AM »
I do thave the stock split block, but since I'm replacing the whole system I might as well get this one. I'm also gonna use the Hydratech brake booster system, thats gonna be interesting.
/ Ken
Offline drewcrane
« Reply #8 on: April 02, 2014 - 08:53:35 AM »
I never needed it so mine is wide open too
