Author Topic: 800 hp hard to believe?  (Read 841 times)
Offline cudabob496
« on: April 02, 2014 - 06:33:50 AM »
New Mopar Muscle mag has a Super Bee with a 500 cu in wedge motor. Edelbrock Victor heads, Super Victor intake, 10.5/1 CR, solid roller .69 lift
and duration at .050 at around 275.  They say WITHOUT nitrous it makes near 800 hp. Does not seem possible with that CR? But, I did not follow
the build that may have been discussed in earlier mags.  Also, that is way to much duration for a CR of only 10.5/1. Wonder if the 800 is a typo?
2011 Kawasaki Z1000
Re: 800 hp hard to believe?
« Reply #1 on: April 02, 2014 - 08:21:28 AM »
Depends , we built a 440 non stroker using those heads & intake with a 660 lift roller cam & EFI & made 710 HP on pump gas at 4000' altitude but 710 HP was a gross rating as used in 1970 not the later net rating used later , of course using the highest # sounds the most impressive which is probably what they did also
Offline Oldschool
  • Member Since 9-05-06
« Reply #2 on: April 02, 2014 - 08:58:01 AM »
I would venture to say that if those 800 hp numbers are true, those Eddy heads have had some extensive port work performed...    :grinyes:
Ken  --  In Georgia
