Author Topic: any one know  (Read 919 times)
Offline 6771plymouth
  • john
any one know
« on: April 02, 2014 - 04:16:23 PM »
passenger side trunk what goes in this hole
Re: any one know
« Reply #1 on: April 02, 2014 - 04:25:50 PM »
You don't mention what car or what year.
I'll assume it's a Challenger, and guess it's a hole for some kind of recovery system for the fuel vapors in the fill tube.
If you have a Cuda, then I truly don't even have a guess.    :banghead:
Offline anlauto
Re: any one know
« Reply #2 on: April 02, 2014 - 04:46:06 PM »
1970-72 Fuel tank vent tube. 70 is different than 71-72 but both Cudas and Challengers had them :2cents:
Offline anlauto
Re: any one know
« Reply #3 on: April 02, 2014 - 04:51:48 PM »
1971 Challenger
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: any one know
« Reply #4 on: April 02, 2014 - 05:08:31 PM »
It is the hole for your vent tube from the fuel tank.  I'm not sure about Cuda's, but '71 Challengers (and later I believe) required these for pollution control.  There were 4 vent lines mounted inside the vent tube down inside the passenger rear quarter with one or two coming from the fuel tank.  I recently replaced my trunk floor with one from AMD and pulled the vent tube and lines out since the new floor did not have this hole.  I am also running a sending and return fuel line.
Offline dfrazz
Re: any one know
« Reply #5 on: April 02, 2014 - 05:11:20 PM »
Also that vent tube is capped at the top and does not go anywhere.
  • john
Re: any one know
« Reply #6 on: April 03, 2014 - 01:45:15 PM »
sry its a 71 cuda,  thank you.. kind of wish I dismantled the car so I know were things go but I bought it in this state so its gona be a long project...  8)
« Last Edit: April 03, 2014 - 01:48:58 PM by 6771plymouth »
Offline CudamanTom
Re: any one know
« Reply #7 on: April 03, 2014 - 02:11:23 PM »
I'm in the same boat with my vert. Luckily I have a hardtop to refer to on most stuff. Both are projects though.
Bought them both stripped down and some stuff I'm learning what goes where.
I'm so lucky to be a memeber on this forum. If these guys on here don't have an answer, then there isn't an answer to be had.  :2thumbs:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
