Author Topic: 1970 E-body parking brake mechanism - spring inside?  (Read 590 times)
Offline shawge
  • Zoiks!!
« on: April 02, 2014 - 09:46:22 PM »
Is there a spring inside the 1970 parking brake mechanisms?  I seem to recall there being one but I only see pictures of the 71+ parking brakes with the spring near the base of the foot lever.
« Last Edit: April 02, 2014 - 11:11:13 PM by shawge »
- Jerry
Offline Moparparts
Re: 1970 E-body parking brake mechanism - spring inside?
« Reply #1 on: April 03, 2014 - 12:36:53 AM »
Yes there is a very small diameter offset end spring inside on the 70 which is commonly broke and missing. It pulls back the small tooth lever to make it engage so your pedal stays down. I have fabbed many of them when i needed them through the years but they may be available repo now. Can also be a bit tricky to instal but not too bad with a spring tool
Offline shawge
  • Zoiks!!
« Reply #2 on: April 03, 2014 - 12:44:27 AM »
Thanks, I found filmsurgeon's photos showing where they go on another site.  Any chance you know how long the spring and offset leads should be?
- Jerry
