Well, looking thru the tool collection I hav found a .79 drill (2mm), and out of curiosity, i might just do that leap, as there's nothing that can't be reworked and back tracked by just buying a set of smaller bleeds.
Thoghts on that? Either that or a more radical restriction in the IFR to get the idle to lean out properly (tried with out the fron IAB. mounted yeasterdy, idles ok and the stink goes away, but does'nt want to rev up properly, go figure
and falls flat and almost stallls when you let the revs down again)
Once the idle mixture is in a better place I will hook up the wideband O2 and start fiddling with the main system. Just afraid I will foul the O2-sensor with this overly rich mixture at idle right now.
