Author Topic: Carb Problem  (Read 1750 times)
Offline cudabob496
Carb Problem
« on: April 04, 2014 - 11:04:01 PM »
My Holley 850 DP has been great for 14 years.  In the last month it is backfiring
more and more duing startup.  Float levels are good, and I recently replace the float
needle/seat assemblies.  Thought timing may be too much, so backed off about 4 degrees,
but still backfiring.  Any ideas?  Maybe I'm due for a total rebuild?
PS Once it starts up, it seems to idle and run fine.
« Last Edit: April 04, 2014 - 11:09:28 PM by cudabob496 »
2011 Kawasaki Z1000
Offline cudabob496
Re: Carb Problem
« Reply #1 on: April 05, 2014 - 01:24:11 AM »
May have found problem. Have a new distributor cap and rotor, installed last year, but now their's a lotta moisture and corrosion in there.
Cap has a vent hole that is capped.  Is that supposed to be unplugged, to vent the cap?
about every piece of metal under the distributor cap has corrosion on it, and there is a lot of greenish copper corrorsion product
on the floor of the distributor. And I live in a dry climate! Why didn't MSD tell me to yank the vent cap off my distributor cap?
I came across this while troubleshooting a backfire, which can be caused by crossed wires, and the like.
Everyone should look under their dist caps for moisture and corrosion.  Can't believe it was this bad
after only 1 year of use!!
« Last Edit: April 05, 2014 - 02:38:57 AM by cudabob496 »
2011 Kawasaki Z1000
Re: Carb Problem
« Reply #2 on: April 05, 2014 - 01:42:24 PM »
You don't remove the cap. There are air passages underneath. The cap is just so moisture cant drip into the vent.
Offline cudabob496
Re: Carb Problem
« Reply #3 on: April 05, 2014 - 02:19:46 PM »
Well, old cap was on there for 10 years, and distributor was dry inside. This new one was on for 1 year,
and lots of rust inside, so I think cap was not allowing venting.
2011 Kawasaki Z1000
Offline cudabob496
Re: Carb Problem
« Reply #4 on: April 05, 2014 - 05:18:46 PM »
Dang, cleaned up distributor, but still backfiring. AFR shows running rich.
Will investigate the power valve next.
2011 Kawasaki Z1000
Re: Carb Problem
« Reply #5 on: April 05, 2014 - 06:00:25 PM »
Exhaust leak can cause backfiring too.
Offline cudabob496
Re: Carb Problem
« Reply #6 on: April 05, 2014 - 06:12:42 PM »
Yep.  With the air cleaner off, its defintely shooting out the carb.  I've read if out the carb, could be lean condition, if
out the exhaust, could be too rich.  But could be other things too. AFR showing rich, so will check power valve.
AFR meters are very valuable if you want to know whats going on in carb.  May have to get new cap and rotor too.
2011 Kawasaki Z1000
Offline jhaag
Re: Carb Problem
« Reply #7 on: April 05, 2014 - 07:23:41 PM »
check all the air bleeds. If you haven't touched it in years, could be blocked. Spray carb cleaner in them and a little compressed air.
love 70 Challengers
Offline cudabob496
Re: Carb Problem
« Reply #8 on: April 05, 2014 - 08:05:23 PM »
ok, thanks. I cleaned them a year ago, but haven't checked lately.
2011 Kawasaki Z1000
Offline cudabob496
Re: Carb Problem
« Reply #9 on: April 08, 2014 - 03:59:01 PM »
Crazy, MSD says my cap might not be venting enough (duh, its a rusty mess), and I should drill a 5/32
inch hole in the side of my cap (which is what I had done on the original cap, and why things were clean
under cap for over 10 years.) Moral of the story, don't trust the vent on your MSD cap for keeping moisture
out of your distributor! The moisture is created by spark ionization.
« Last Edit: April 08, 2014 - 09:44:33 PM by cudabob496 »
2011 Kawasaki Z1000
Offline erat340
Re: Carb Problem
« Reply #10 on: April 08, 2014 - 09:09:20 PM »
Try this... spray a light mist of WD40 on the inside of the dist cap and see if it runs better, old trick of mine.
Offline cudabob496
Re: Carb Problem
« Reply #11 on: April 08, 2014 - 11:03:24 PM »
Something to keep in mind!
My guess is my distributor got all messed up from moisture and corrosion, which then caused the backfire, which blew my power valve.
I told MSD they need to redesign thier product so this does not happen. Their vent is inadequate.
I live in a dry area, with low humidity, and my distributor internals still rusted up!
2011 Kawasaki Z1000
Offline cudabob496
Re: Carb Problem
« Reply #12 on: April 12, 2014 - 10:57:21 PM »
Well, problem solved, thankfully. New cap and rotor, and new power valve, and all seems back to normal.
That MSD cap and rotor was only in there for about 1500 miles, and corroded itself to death, because the vent
either wasn't working, or is too small.  Gonna see if I can get my money back for those.
I read somewhere that 90% of problems with an engine are usually electrical, with fuel related issues
being only about 10%. Beginning to believe it.
Anyway, make sure to vent your distributor cap. I put two 1/4 inch holes on the side of this new one. The side
facing the headers, so dirt can't freely fall in there.
2011 Kawasaki Z1000
Re: Carb Problem
« Reply #13 on: April 13, 2014 - 12:11:33 AM »
Two 1/4" holes?!? Think that's enough?
Think you went kinda extreme there.....
Offline cudabob496
Re: Carb Problem
« Reply #14 on: April 13, 2014 - 03:35:31 AM »
I had one 3/8 hole on my old MSD cap, and it lasted 12 years.  These two 1/4 inch holes are about 2 inches apart.  Don't see
that it can hurt anything, and should help keep things dry.
I assume, with 8 pickups, and several thousand RPM, there is a significant spark show going on inside the distributor cap, with the build
up of humidity.  I suppose the size of the vent hole(s) will determine how quickly things dry out in there, after the car is shut off. MSD is
known for making some big sparks, with a lot more energy than a standard stock distributor.
PS, good Mopar story:
https://www.youtube.com/watch?v=zlnocas2IjM
« Last Edit: April 13, 2014 - 04:56:46 AM by cudabob496 »
2011 Kawasaki Z1000
