Author Topic: Autometer 340 sender location help please...  (Read 782 times)
Offline AU6pack
« on: April 05, 2014 - 01:11:14 AM »
Hi guys. I have just bought mechanical Water temp, Oil pressure & Oil temp Autometer gauges going into a 340.
I am figuring out where to mount them and am a little unsure of the sender locations  :clueless:
I believe the oil pressure sender is next to the distributor? Yes?
The water temp sender is on the water pump? It has the original electric sender so I am assuming the Autometer unit will replace the electric sender?
Where does the oil temp sender go?
Any tips appreciated and photos would be great. I am sure many of you have done this replacement before.
Thanks.
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Offline hooD
  • detroit iron
  • Motor City Made Muscle
Re: Autometer 340 sender location help please...
« Reply #1 on: April 05, 2014 - 06:08:39 AM »
Thanks.
oil sending unit is behind distributor...you can see where the oil line goes in this picture.  This is for oil pressure, not oil temp..
water temp sender
« Last Edit: April 05, 2014 - 11:58:58 PM by hooD »
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
« Reply #2 on: April 05, 2014 - 06:47:51 AM »
Oil temp sensor goes in a bung on the oil pan. Most oil pans will not have provisions for one.  You could mount it in a "manifold" on the cooler lines if you had an oil cooler. In all honestly you don't need an oil cooler on a street driven engine .(or a gauge)  :2cents:
Offline DocMel
« Reply #3 on: April 05, 2014 - 01:37:24 PM »
Not sure about the oil temp gauge:  To me, for the average street car, oil pressure and water temp are more likely to be more important than an oil temp gauge
Offline AU6pack
« Reply #4 on: April 07, 2014 - 05:11:53 AM »
Thanks for the tips guys. Appreciated  :bigsmile:
Craig
