Author Topic: Speedo Gear  (Read 2056 times)
Offline bighig340
  • Ride Hard, Ride MOPAR!!!
Speedo Gear
« on: July 25, 2002 - 02:51:38 AM »
How hard is it to change the speedo gear in a auto727?
Any helpful info will be greatly appreciated.
Re:Speedo Gear
« Reply #1 on: July 25, 2002 - 03:30:15 AM »
Not hard but still a pain, there is a single 7/16 bolt holding a forked clip that holds the speedo housing in , but when you pull it 2-3 qts of trans fluid will leak out.
There are 3 different diameters of speedo gears , you need to match the # of teeth on the gear to the number range cast onto the housing & line up the notch for the # of teeth  with the nub cast onto the trans tailshaft or you will have problems. clean the area & look at the line up before you remove the speedo housing   ;)
Offline AustinChallenger
Re:Speedo Gear
« Reply #2 on: July 25, 2002 - 01:56:33 PM »
He summed it up well.  I had to replace mine and it wasn't hard, just a hassle.
1974 #'s matching Duster 360
Offline gizzard-1
Re:Speedo Gear
« Reply #3 on: January 04, 2003 - 02:54:07 AM »
Lucky me, I changed mine before I installed it. ;D
2nd place is for the 1st place loser!
02 Ram Big and Red
73 'Cuda Yellow
70 Charger 500 Black
