Author Topic: Oil pressure sending unit  (Read 487 times)
Offline blown motor
« on: April 06, 2014 - 07:46:02 PM »
Pulled the car out today and the oil pressure gauge on the rallye dash showed 0. Looked for the sending unit to check the wire and I couldn't find the darn thing  :banghead: Where is it?
Re: Oil pressure sending unit
« Reply #1 on: April 06, 2014 - 08:03:13 PM »
grey wire near the ballast resistor in the firewall harness
« Reply #2 on: April 06, 2014 - 08:06:12 PM »
At the very rear of the intake manifold, top centre. Mounted vertically.
Offline blown motor
« Reply #3 on: April 06, 2014 - 08:08:23 PM »
I thought it was on the back of the motor but I couldn't see it. I'll have to look again. Drivers side or passengers side from the distributor?
Offline jimynick
« Reply #4 on: April 06, 2014 - 10:16:27 PM »
Murray, it's in the block, behind the distributor, pretty much in the middle. It's 1/8" pipe, usually round and about 1 1/4" approx in diameter. Hope that helps! Ian  :cheers:
