Author Topic: How to reduced steering extention/length?  (Read 1439 times)
Offline AU6pack
« on: April 08, 2014 - 08:18:07 AM »
Hi guys,
The steering wheel is so close i feel like I'm in a NASCAR. Is thee any way to reduce the size of this extension housing? I have looked everywhere on line and cant seem to locate an extension that's not stock. I would like about a 2" piece but they don't seem to exist. Any tips?
I cant drive the car (properly) with the steering wheel so close....
What are your set ups?
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Offline Jesus H Chrysler
Re: How to reduced steering extention/length?
« Reply #1 on: April 08, 2014 - 08:26:15 AM »
Some Dodge trucks, Volare/Aspens and late 70's Chrysler 300's came with Tuff wheels and needed a short adapter.  I had one on my Ramcharger back in the day.  This is just the first one I came across.  I'm sure you can find them cheaper if you seek out truck or Volare parts.
http://www.ebay.com/itm/ORIG-MOPAR-RIM-BLOW-STEERING-WHEEL-ADAPTOR-70-71-72-CHARGER-DART-SUPER-BEE-TUFF-/191127883226
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Offline AU6pack
« Reply #2 on: April 10, 2014 - 11:56:58 AM »
Not much luck. Do you know if these can be cut and joined?
Is there any aftermarket crush can replacements that are around 2"? I'm lost...
Craig
« Reply #3 on: April 10, 2014 - 12:36:18 PM »
They're metal, they can be cut and welded back together.  But now you're trusting the welder to know what they're doing and not end up with an unsafe or crooked steering wheel.
There are many other adapters out there if you can't find a factory one you like.  Here is one from Ididit:
http://www.ididitinc.com/accessories-3/SteeringWheelAdaptors_Acc-16
{OO /===\ OO}
(OO==> <==OO)
Offline Devil
  • Forward, Together Forward
    • Ryan's Cars in Barns
« Reply #4 on: April 10, 2014 - 07:00:45 PM »
Here is the two cans he was talking about.
Unfortunately the issue is because the steering wheel is moved so much, now on most E-body and even the Tuff Wheel, your knuckles will impact the leading edge of the dash.  That's been my issue.
http://www.flickr.com/photos/hemipwr70/
http://carsinbarns.blogspot.com
71 Challenger R/T Clone
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
88 Caprice Classic Brougham
Offline tommyg29
« Reply #5 on: December 17, 2014 - 10:42:49 PM »
This is an old thread but thought Id contribute.
I had the same problem, so I cut out the middle 5 or 6 ribs, and had the two halves welded back together. Then I just ground down the high spots, bondo filled the low spots, and primed, painted and done. Looks factory, but about half the length.
Just make sure you dont cut too short or your fingers will hit the dash, and hope you dont get in an accident, because a poorly welded can will break instead of "crush", and it could impale your chest.
Not a pretty thought.
Offline 73EStroker
« Reply #6 on: December 21, 2014 - 08:44:20 PM »
Don't forget the indicator stalk will also need to be modified/straightened to clear the rim if it is moved closer to the dash. I have considered doing what Tommy did. I will check the pick a part yards first for shorter ones.
Barry (Salmon Arm)
Offline tommyg29
« Reply #7 on: December 21, 2014 - 10:12:32 PM »
I forgot about that. I hand bent the lever carefully about one inch
