Author Topic: Big block MSD ignition wire advice  (Read 1460 times)
Offline tommyg29
« on: April 09, 2014 - 10:24:24 PM »
As stated, my very mild build 440-6 has the MSD6 system with the blaster coil.
If I change wires (mine are at least 8-10 years old) should I go with the 8.5mm msd type wires, or will the "oem" orange 7mm wires be perfectly adequate.
I would prefer the orange color. Blend in a little better, plus theyre cheaper.
Champion plugs are gapped at .048 to .050
I think the orange type are made better now than the originals, but will they work well with the multiple spark?
Thanks again.
« Last Edit: April 09, 2014 - 10:36:32 PM by tommyg29 »
Offline Strawdawg
    • Vortex Buicks
Re: Big block MSD ignition wire advice
« Reply #1 on: April 09, 2014 - 10:50:03 PM »
I think they will be fine
the wider gap will cause the voltage to be a bit higher than it would be at 0.035" but not that much more.  Given that you are not running very high compression at high rpm, I think they will work ok.
Just follow good practice and don't parallel two wires in the looms that go to cylinders that fire one after the other in the firing order.  You should do this no matter what wire is being used... :)
Steve
« Last Edit: April 09, 2014 - 11:31:17 PM by Strawdawg »
Offline jhaag
« Reply #2 on: April 10, 2014 - 09:02:10 PM »
check out taylor wires, quality wires in a variety of colors and sizes
love 70 Challengers
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: April 10, 2014 - 09:51:10 PM »
Just no solid core wires
« Reply #4 on: April 10, 2014 - 10:29:58 PM »
I would go with the 8.5mm wires. I look at it this way, why upgrade everything but the wires - which conduct the power to the plug?
« Reply #5 on: April 10, 2014 - 10:30:52 PM »
I like spiral core Firecore are supposed to be excellent wires
Offline stinger
« Reply #6 on: April 11, 2014 - 11:05:50 PM »
^^^ Yep,like my firecores.I did have to use an accel ceramic on 1 cylinder due to header though.
« Reply #7 on: April 13, 2014 - 01:18:47 PM »
Orange wires will just have the carbon core , spiral is far better , wire technology has come a long way since the 60s
Offline Strawdawg
    • Vortex Buicks
« Reply #8 on: April 13, 2014 - 06:43:45 PM »
Spiral wires are the only ones to buy for long life
Steve
Offline slsc98
« Reply #9 on: April 15, 2014 - 07:38:55 PM »
If I change wires . . .
Jes curious if you made your choice and, if so, if you've had an opportunity to try out whatever set you decided on?
I'm in the processing of swapping out my wires, plugs and the distributor cap and rotor, as well.
(I probably should've asked here first but, I went ahead and spent $ on a complete set of wire routing brackets for my stock engine, ordered 'em from Mega Parts. No more wire b.s. rigging (hopefully)!
Offline tommyg29
« Reply #10 on: April 16, 2014 - 01:54:23 PM »
Havent ordered them yet because Im trying to get my rebuilt six packs set up running properly first.
But I will advise when I do.
 :2thumbs:
