Author Topic: Upper control Arm Cam Bolts question  (Read 1775 times)
« on: April 11, 2014 - 10:59:19 PM »
I put my upper control arm Cam bolts in thru the upper control arms.
On from the inner fender, underneath towards the engine compartment side. (Facing out each way)
I need pictures and measurements if possible, how long the bolt sticks out on the engine side.
'Also, what is the total length.of the cam bolts by themselves?
Mine look like they're too long or I need special nuts that are wider?
 :feedback:
« Last Edit: April 11, 2014 - 11:20:23 PM by Topcat »
Offline hemiken
Re: Upper control Arm Cam Bolts question
« Reply #1 on: April 11, 2014 - 11:10:39 PM »
Have you got the correct cam adjusters on all of them ? there is two cam washers per bolt..............
Post up a picture of what you have done TC :2thumbs:
Offline 1973JA5
« Reply #2 on: April 12, 2014 - 04:56:54 PM »
Drivers side,front and rear.Passenger side front and rear.73 Challenger,Raybestos Part #6161013,plus/minus 2 1/2 degrees.
« Reply #3 on: April 12, 2014 - 10:06:11 PM »
Thanks for the pictures.
I believe that confirms mine are correct.
I just thought it was wierd that they stuck out so far.
Mine measured 4.25" end to end.
« Reply #4 on: April 13, 2014 - 08:37:50 PM »
I'm thinking there must be different lengths available. My cam adjuster bolts only stick out about 1/8" past the nut.  :clueless:
« Reply #5 on: April 13, 2014 - 08:43:41 PM »
I received this e-mail on some UCA Cam bolts on E bay I inquired about.
"total length of the bolt, including the head, is 4 inches"
These were A body.
E body is 4.25" according to mine I measred.
Difference is minor. I suspect either were used on E bodies.
« Reply #6 on: April 13, 2014 - 11:17:19 PM »
It's weird, the fastener guide doesn't list a length. Both my Challenger and Dart cam bolts are 4" long overall. They have one flat on them and were phosphated. The aftermarket replacements are usually a little longer. Sometimes they have two flats on them. Most are also zinc plated.
« Reply #7 on: April 14, 2014 - 12:00:51 AM »
From the pictures, it looks like these are special nuts. Wider than the normal width.
Are they?
« Reply #8 on: April 14, 2014 - 09:09:06 AM »
Yes, the nuts are wide...kind of like the rear end U-bolt nuts.
