Author Topic: Power to maunal brakes with a 2 bolt MC - ? about gaskets  (Read 531 times)
Offline shawge
  • Zoiks!!
« on: April 12, 2014 - 07:05:48 PM »
I'm converting from power to manual brakes.  I've got the the 15/16" master cylinder, 2-bolt adaptor, firewall stiffening plate, and adjustable push rod.  I have a question about gaskets.  I know there's one between the firewall and the stiffening plate.  Is there supposed to be a gasket between the 2-bolt adaptor and  the stiffening plate, and one between the MC and the 2-bolt adaptor?  I've got the gasket set from DMT and one of gaskets looks like it would work between the adaptor and firewall plate, but nothing for the MC.
- Jerry
Offline anlauto
Re: Power to maunal brakes with a 2 bolt MC - ? about gaskets
« Reply #1 on: April 12, 2014 - 07:11:27 PM »
Seeing how you're modifying the car, there really is no rules...You can put gaskets where you feel is necessary. :2cents:
Offline shawge
  • Zoiks!!
« Reply #2 on: April 12, 2014 - 07:18:51 PM »
Thanks Alan.  LOL, yes, that is true.  I was worried about water/fume infiltration.  I guess I can use some RTV between the MC and adaptor.
- Jerry
